  • V-Tail Quad Scratch Build
[Today at 12:52:16 PM]
[Today at 11:31:57 AM]
Pages: [1] 2 3 ... 6
Author Topic: V-Tail Quad Scratch Build  (Read 12350 times)
« on: May 17, 2013, 10:45:09 PM »
Well after crashing my QAV400 I thought I would try a scratch build whilst Im waiting for spares to be shipped. Was originally going to build a H quad but always wanted to try a TRI too however put off by servo and tilt mechanism so settled on a V-Tail quad. I already had the ply, the other bits came to about £15, £10 of which is the 2 lengths of aluminium section used. Im going to fit the electrics tomorrow and run it on the KK2.0
Re: V-Tail Quad Scratch Build
« Reply #1 on: May 17, 2013, 11:18:03 PM »
ooooh, shiny
Hoversight
« Reply #2 on: May 17, 2013, 11:20:51 PM »
Neat! ... but don't be too put off by a servo tilt mechanism. Should you ever want to try a Tri, then the Turnigy Talon Tricopter Integrated Tail Servo Mount Set with a TGY-306G-HV High Voltage Ultra Fast/High Digital Servo and a Blade 400 thrust bearing will give you a solid yaw mechanism. (the thrust bearing is the key. The 306G servo isn't as robust as the 306G-HV)
http://www.hobbyking.com/hobbyking/store/__25561__Turnigy_Talon_Tricopter_V1_0_Integrated_Tail_Servo_Mount_Set.html
http://www.hobbyking.com/hobbyking/store/__31880__TGY_306G_HV_High_Voltage_Ultra_Fast_High_Torque_MG_Digital_Alloy_Cased_Servo_3_7kg_UK_Warehouse_.html
http://www.bladehelis.com/Products/Default.aspx?ProdID=EFLH1420
« Reply #3 on: May 17, 2013, 11:35:03 PM »
The Hv1 i Like it , you planing on rear motors facing down ?
« Reply #4 on: May 18, 2013, 12:28:18 AM »
yup rear motors down, got motors on now soldering to do tomorrow
« Reply #5 on: May 18, 2013, 07:38:21 AM »
Oh yea, scratch build, scratch build!
Lot of fun, not a lot of expense...
« Reply #6 on: May 18, 2013, 11:42:53 AM »
Ben , watching with interest. Fancy a go at one of these myself. Some details on dims and construction method would be really good when you know it works :-)
« Reply #7 on: May 18, 2013, 01:44:08 PM »
sweet ben watching with interest m8,,,could be a job for me this year about time i actually built something lol
« Reply #8 on: May 18, 2013, 07:28:34 PM »
Some piccys, the lego block legs are temporary, all out of building energy right now so will revisit the legs later.
« Last Edit: May 18, 2013, 07:35:41 PM by MrBen »
« Reply #9 on: May 18, 2013, 07:41:51 PM »
looks pretty cool that ben ...sweetness
« Reply #10 on: May 18, 2013, 07:42:51 PM »
Tidy,plenty of room onboard
Hoversight
« Reply #11 on: May 18, 2013, 07:43:40 PM »
Option to carry a load by plugging into the lego landing gear?
« Last Edit: May 18, 2013, 07:48:32 PM by Hoversight »
« Reply #12 on: May 18, 2013, 07:43:59 PM »
Bloody loving the Lego :)
« Reply #13 on: May 18, 2013, 07:48:20 PM »
Quote from: Ant on May 18, 2013, 11:42:53 AM
Specs :
Weight 823grams or with 4s 2650mah lipo 1120grams, 10min hover in garden and put back 1871mah into the lipo which is 70%
Overall length of frame is 472mm, Width of front aluminum section is 600mm, flat section on rear is 72mm then each 30deg slanted piece is 129mm each. Measurement between front motor shafts is 558mm, between rear motor shafts at prop level is about 270mm, between front and rear is about 485mm, whether any of this is right is yet to be proved in flight.
Aluminum box section is from b&q and is 10mmx10mmx1mm thick x 1m long for about £5, angle is 14mmx14mm and costs about a fiver too, centre section is 10mmx10mm wood and 4mm ply top and bottom however there is a little flex if I twist the front end across the back whilst holding the rear, I may yes replace the 4mm ply for 6mm or change the 10mm wood for 10mm aluminium or it may just be fine as it is :)
« Reply #14 on: May 18, 2013, 07:50:14 PM »
ha ha lego landing gear is temporary, underslung rear props would be in the dirt so I wanted to lift it up for testing.
[Today at 07:17:14 PM]
Page created in 0.944 seconds with 21 queries.
