  • V-Tail Quad Scratch Build
[Today at 10:09:52 PM]
[Today at 09:59:09 PM]
[Today at 09:27:22 PM]
What did the postman bring you today? by gavnthat
[Today at 07:09:26 PM]
[Today at 07:04:50 PM]
[Today at 06:50:53 PM]
[Today at 05:11:44 PM]
[Today at 01:48:41 PM]
[Today at 09:22:18 AM]
Chasing mr.ben by bigMouse
[May 04, 2015, 04:40:29 PM]
Setting up a mix on taranis **HELP** by MrBen
[May 03, 2015, 09:12:39 PM]
[Today at 10:06:29 PM]
New 250 FPV Racer by JUST CRASH
Pages: 1 ... 4 5 [6]
Author Topic: V-Tail Quad Scratch Build  (Read 12543 times)
Re: V-Tail Quad Scratch Build
« Reply #75 on: August 28, 2013, 05:00:32 PM »
Quote from: Vass on August 27, 2013, 03:47:25 PM
OK Cool thanks
any advice how to adjust the power curve on the throttle so I have less reaction between 30% and 60% stick movement ?  it's just to violent at the moment.
ta
Throttle curves are usually done on the TX, some TX will only let you use a curve when in heli mode, sometimes you can set a throttle curve with the flight controller like on the copter control cc3d for example.
Vass remember so swap the motor wires for 3-4 back around, I understand they dont need to be reversed for upward facing rear motors.
Offline Vass
    • My photography
« Reply #76 on: August 28, 2013, 05:35:04 PM »
Thanks MrBen
Yes clocked the motors 3&4 needed reversing and on the KK2 too
Thanks for your help again :-)
www.doubleyolk.co.uk
« Reply #77 on: September 15, 2013, 08:33:30 PM »
Hey Vass any luck with the new motors/props?
Offline Vass
    • My photography
« Reply #78 on: September 15, 2013, 09:17:03 PM »
Ive had a good run albeit short with same motors in the 'A' tail format
Ive got the motors ready to swap over, just need to get on and do it.
Got the USB for the firmware too, just need to crack on.
« Reply #79 on: September 15, 2013, 09:24:28 PM »
Cool, when u get hd cam on her post a vid
Offline Latrolobos
  • Newbie
« Reply #80 on: January 10, 2014, 09:50:23 PM »
Mr. Ben,
Sweet design.  I've been drooling over it for the past few hours.  I've been working on a design for carrying a Tarot 2D mounted topside/upside down for fpv.
The original though was to go with a slightly modified H-Quad, but the V-Tail is awesome looking and looks like fun to make.
Before I go and make everything in sketchup do you have anything already drawn up?  Also,  I've been looking around for design dimensions or ratios for V-tails in general, but i'm coming up short.  This is what I have so far:
Start with a tricopter-design - 120 degrees apart from FC.
Convert the tail into a V - 90 - 120 degrees apart (change dist to fc depending on angle).  depends on yaw/thrust mix, different prop size from front.
Any help/advice would be appreciated.
« Reply #81 on: January 10, 2014, 10:03:59 PM »
I dont have anything drawn up but all the measurements are on this post
https://fpv-forum.com/index.php?topic=2421.msg15656#msg15656
Wasnt as smooth to fly as my qav400 quad but I always felt it made better video perhaps because it was generally more stable
Offline Latrolobos
  • Newbie
« Reply #82 on: January 11, 2014, 12:21:23 AM »
Totally missed that post thanks!  I'll post a sketchup of it
Sent from my SC-04E using Tapatalk
  • user meluk
[Today at 09:02:25 PM]
Page created in 1.033 seconds with 21 queries.
