  • V-Tail Quad Scratch Build
[Today at 10:09:52 PM]
[Today at 09:59:09 PM]
[Today at 09:27:22 PM]
What did the postman bring you today? by gavnthat
[Today at 07:09:26 PM]
[Today at 07:04:50 PM]
[Today at 06:50:53 PM]
[Today at 05:11:44 PM]
[Today at 01:48:41 PM]
[Today at 09:22:18 AM]
Chasing mr.ben by bigMouse
[May 04, 2015, 04:40:29 PM]
Setting up a mix on taranis **HELP** by MrBen
[May 03, 2015, 09:12:39 PM]
[Today at 10:06:29 PM]
New 250 FPV Racer by JUST CRASH
Pages: 1 2 [3] 4 5 6
Author Topic: V-Tail Quad Scratch Build  (Read 12541 times)
Offline Vass
    • My photography
Re: V-Tail Quad Scratch Build
« Reply #30 on: August 17, 2013, 12:47:38 AM »
Video brought me here, very smooooth, great build.
Whats the fpv antennas? Look like whips?
And why two? Is one he radio receiver? Sorry never seen a setup like that.
Ta, keep up the good work
Vass
www.doubleyolk.co.uk
« Reply #31 on: August 17, 2013, 06:02:44 AM »
Back antenna is 433 UHF whip, front antenna is stock whip on racewood 1.2 vtx.
Thanks for dropping in :)
« Reply #32 on: August 17, 2013, 09:24:29 AM »
Ben - where do you buy your 1.2 gear from ? Is it significantly better than 2.4 ?
« Reply #33 on: August 17, 2013, 09:30:26 AM »
drones vision, I also use lawmate vtx too which Hobby King sell now, for ages I had a good 2.4 pic then it just went bad and I couldn't get it back so I completely changed my whole ground station setup and frequency.
Offline Vass
    • My photography
« Reply #34 on: August 17, 2013, 10:40:49 AM »
Quote from: MrBen on August 17, 2013, 09:30:26 AM
Isnt 1.2 jail territory in UK? Air traffic contol frqeuncy? (Just askin)
And whats on the gopro lens?
Apols for all the Q's, i'm building to your spec today. Gonna use Ali U section down the centre fuselage.
« Reply #35 on: August 17, 2013, 11:45:05 AM »
sorry did i say 1.2 I meant 25mw 5.8 :)
Thats a layer lens to protect the gopro lens http://www.getfpv.com/accessories-51/layerlens.html
Offline Vass
    • My photography
« Reply #36 on: August 17, 2013, 11:45:58 AM »
Ta for reply, B&Q here I come :-)
One more thing,  (and most important) where did you put the CG ?  :-)
« Last Edit: August 17, 2013, 12:09:17 PM by Vass »
« Reply #37 on: August 17, 2013, 12:16:48 PM »
Quote from: Vass on August 17, 2013, 10:40:49 AM
more like stern letter followed by fine territory (if they even find you)
Quote from: Vass on August 17, 2013, 11:45:58 AM
for best efficiency and reliability, you want all 4 motors spinning at the same speed, producing the same thrust. on a normal quad you'd draw imaginary lines from opposite motors (diagonally) and the CG should be where the lines make a cross.
with a V tail, I'm not too sure. I think you'd treat the rear 2 motors as a single point of down thrust, and make a triangle with the front 2 motors, putting the CG in the middle of that triangle.
« Reply #38 on: August 17, 2013, 12:34:31 PM »
If I remember correctly it was slightly forward of the half way mark on the centre section, I kinda thought that as the back to motors lost some thurst with them being at 30 deg angle then it made sense to put the cog about a quarter of the distance between the centre and the front.
Offline Vass
    • My photography
« Reply #39 on: August 17, 2013, 07:29:02 PM »
just had 2 hours of fun in the garage, not trying to thread nap, just thought I'd share :-)
Finished article :-)
Only changes are the Ali struts down the fuselage and 6mm ply as per MrBens suggestion
and I've set my V angle at 35 degrees
« Reply #40 on: August 17, 2013, 07:58:55 PM »
Post away! Looks surprisingly familiar ;)
I wonder how much stiffer it is than my 4mm ply version, mine could twist a bit if I held the rear and tried to rotate the front. You could probably do with some more bolts along the length too to stiffen even more.
Offline Vass
    • My photography
« Reply #41 on: August 17, 2013, 08:29:20 PM »
I can't twist it at all, very strong, probably a bit heavier though.
Offline Vass
    • My photography
« Reply #42 on: August 18, 2013, 09:57:26 PM »
Quote from: Vass on August 17, 2013, 08:29:20 PM
Ben, what setup did you use on the KK2 as regards the rear two motors, i'm reading all about
Swapping them over and reversing power , all sorts of different methods on V quads
« Reply #43 on: August 18, 2013, 10:39:03 PM »
just swap the esc wires for motors 3 and 4 on the flight controller and of course make sure the props are spinning the right way too.
Offline Vass
    • My photography
« Reply #44 on: August 22, 2013, 02:25:19 PM »
Parts arrived today so thats My Bank Holiday sorted ! :-)
  • user meluk
  • user Smit80
[Today at 09:02:25 PM]
Page created in 1.397 seconds with 20 queries.
