  • kvosd / mwosd Perfect Companion for naze32
Pages: [1] 2 3
Author Topic: kvosd / mwosd Perfect Companion for naze32  (Read 4875 times)
« on: July 09, 2014, 10:15:14 PM »
used a cheapo hobbyking osd at first but for the price of them got a minim osd off ebay and flashed kvosd for spanky , its perfect addon realy for naze users same weight as mini hobbyking osd 7g and you don't need Bluetooth module to change setting and tune pids , depending on what receiver yo have you might need to do a little soldering but for ezuhf users its pretty simple f yo just want voltage and rssi you can pass it all from flight controller with no extra wires
for rssi
set your channels for ppm muxed in irc tools and add link quality as channel 8
and then RSSI_AUX_CHANNEL = 4 in cli on naze and calibrate as in video below
https://www.youtube.com/watch?v=c5u4zDxq-wk
realy good video to follow on this here on yt covers the rest of setup
https://www.youtube.com/watch?v=ikKH_6SQ-Tk
« Last Edit: August 16, 2014, 08:41:36 PM by Martink1974 »
Re: kvosd Perfect Companion for naze32
« Reply #1 on: July 09, 2014, 10:16:04 PM »
Reserved
« Reply #2 on: July 09, 2014, 10:45:48 PM »
oo nice thread
« Reply #3 on: July 10, 2014, 02:55:45 AM »
ummm looks tempting, don't know if i want to add more stuff to my mini though like how it looks so bare after my messy qav
« Reply #4 on: July 10, 2014, 08:40:49 AM »
Thanks for the info!
What soft did you use to create that sketch?
Good idea but wouldn't use it on a mini, trying to pare as much weight as possible...
« Reply #5 on: July 10, 2014, 02:07:01 PM »
arduino sdk kv sketch was created by kvteam
the osd is very small same weight as hobbyking I used to use for just voltage check , it actualy saves a few grams if you loose bt module
no point in gps and all the other stuff its supports though
« Reply #6 on: July 27, 2014, 10:17:07 AM »
Martin are you running 12v through the minim osd then?
« Reply #7 on: July 27, 2014, 10:49:20 AM »
No don't just power it from 5v side and just run video signal through and no 12v , can't be sure what version our boards are and the voltage reg might get hot n pop
What people refer to as 5v mod is already done , when you power from 5v side you should get light on both sides of board
« Reply #8 on: July 27, 2014, 08:11:03 PM »
I've got a minim osd on my naze too and inject my RSSI through my PPM on my openlrsng so I get RSSI all the way from rx to naze to osd in one wire. I would recommend getting a minim from witespy as it's pre modded for kv osd firmware and generally cheaper than chinese clones anyway. Also look into multiwii osd firmware it works with baseflight and minim and appears to be slightly better. I'm flashing it tonight
Sent from my SM-N9005 using Tapatalk
« Reply #9 on: July 27, 2014, 10:40:25 PM »
Quote from: papa_lazerous on July 27, 2014, 08:11:03 PM
I did flash it and it does look better , some options re not working properly , in the osd config itself the gui config seems to work mostly , gunna test it on one of my spankys , but so far setting up voltages seems abit more flaky but im sure it will work sweet with a little more messing
cant seem to get virtual current sensor to work either , shame
« Last Edit: July 27, 2014, 10:42:14 PM by Martink1974 »
« Reply #10 on: July 27, 2014, 11:25:18 PM »
Did you uncomment the line in arduino before flashing? Think it's in config.h can't remember for sure. Just search for the text baseflight to find it. Also if you look on google code under issues there's a comment about voltages being a little off and an edit to make to the code to fix it.
« Reply #11 on: July 28, 2014, 09:03:02 AM »
Quote from: papa_lazerous on July 27, 2014, 11:25:18 PM
I didn't papa , i will have a read in a bit thanks for info , so how did you find it
« Reply #12 on: July 28, 2014, 09:11:33 AM »
I think I saw reference to it on the lab but then spent ages searching and found very little info and figured the arduino stuff out myself. I've got everything ready to go now just need to fly!
« Reply #13 on: July 28, 2014, 07:15:15 PM »
Well just maidened new spanky with kvosd 2.2 and i couldnt update the PIDs via the OSD, it just wouldnt save any changes I made. Same as it was doing with yours Martin @ Brinscall. What was the fix?
« Reply #14 on: July 28, 2014, 07:26:23 PM »
did not find one its weird cos it lets you save rssi data , ill test mw osd tonight
Pages: [1] 2 3
  • Dot Guests: 35
Page created in 1.193 seconds with 22 queries.
