Equipment
Video Equipment
kvosd / mwosd Perfect Companion for naze32
old hat futaba & Campac stuff
at 08:52:50 AM]
at 04:57:21 AM]
cold weather camera
Gopro Live out through switcher video problem
spring is in the air
Spanky 5 Dropped From the Sky
Wipeout Series #6 - The "grand" gravel pit
MatthiasC
Scottish Borders Counties Rally Aerial Fotage HD
Hi from Liverpool
marks emax 250 proper maiden at long last
Cobs mini Tricopter on 2s with 5x3 props
New TV Format FPV
Pages:
2
3
Topic: kvosd / mwosd Perfect Companion for naze32 (Read 4884 times)
Re: kvosd Perfect Companion for naze32
Reply #15 on:
July 28, 2014, 07:27:32 PM »
well I will either try kv2.3 or mwosd later
I am a leaf on the wind; watch me soar
Reply #16 on:
July 28, 2014, 09:14:01 PM »
did try mw osd before , worked ok in flight
rssi when working with ezuhf seems to respond slightly slower (not much takes a extra sec to reactwhen turn of uhf tx)
on other hand pwm rssi is reported to work so you might want to tag off pin 26(rssi) and 21(gnd) ben and connect them up will prolly function better
saving pids now works (big plus for me with no bt)
virtual current sensor don't show amps no matter what I do (prolly still under development)
Im gunna put it on both of mine the pc gui is better and its in development where has kv development has stopped at 2.3
will have to hook up a gps when I put a naze32 on something bigger
naze32 4 win
I did edit config.h before compiling in arduino
uncomment following lines
#define BASEFLIGHT // Undefine this if you are using BASEFLIGHT / others to correct for incorrect heading - (thanks papa)
#define FASTPIXEL // Optional - may improve resolution - especially hi res cams - (was better with my cam that's 800tvl)
Last Edit: July 29, 2014, 10:22:49 PM by Martink1974
Re: kvosd / mwosd Perfect Companion for naze32
Reply #17 on:
July 30, 2014, 06:21:49 AM »
Here is KVOSD in action
KVOSD 2.2 on a Spanky FPV Quadcopter
Small
Large
papa_lazerous
Reply #18 on:
July 30, 2014, 10:27:56 AM »
Thanks for the heads up about the fast pixel define I wasn't aware of that. I'm going to flash the other font pack later to compare
Sent from my SM-N9005 using Tapatalk
Reply #19 on:
July 30, 2014, 06:29:39 PM »
looks great, nice and clean just the essentials on there you need. the altitude didn't look very accurate though, was saying you was 20m up when you was about 3m
Reply #20 on:
July 30, 2014, 06:31:38 PM »
yeah I didnt have a sponge/foam over my baro, cant find them on ebay uk for a tenner anymore now either
Reply #21 on:
July 30, 2014, 06:40:45 PM »
can you get ground speed on there?
Reply #22 on:
July 30, 2014, 06:50:57 PM »
yes if you add a gps
Reply #23 on:
July 30, 2014, 06:54:30 PM »
thats good to know could replace tiny with it on the qav, unless i go with the naza on there
Reply #24 on:
August 01, 2014, 12:15:15 AM »
help calibrating mw osd
Calibration - Voltage
Main or video voltage connected directly to OSD
1.If > 4s select "Enable ADC 5v ref"
2.If "Enable ADC 5v ref" is changed, save and restart the OSD
3.With a voltage meter, change "Voltage adjust" and save until the voltage on the OSD matches the meter
4.Repeat for video if appropriate
Calibration - Current
Hardware current sensor - with a current meter
1.Select "Enable ADC 5v ref"
3.Starting at zero, increase "Zero adjust" to display correct Amps at motors off
4.Starting at max, decrease "Amps adjust" to display correct Amps at mid - high throttle setting
Software current sensor - with a current meter 1.Starting at zero, increase "Zero adjust" to display correct Amps at motors off
2.Starting at max, decrease "Amps adjust" to display correct Amps at approx hover
Software current sensor alternative method - with a battery charger
1.Change "Zero adjust" to display correct Amps at motors off - typically 0.3
2.Change "Amps adjust" to display "approx" correct Amps at mid throttle ( try bat capacity*8 where capacity is in Ah )
3.Fly a complete battery and note the total mah used on the OSD and put back into the battery by your charger
4.The correct amp adjust = old amp adjust * charger mah used / OSD mah used
Calibration - RSSI
1.If using analogue RSSI on the OSD select "Enable ADC 5v ref"
Via OSD menu
1.With TX approx 2-3 m from the RX, select calibrate RSSI from OSD menu
2.When timer reaches 10, turn the tx off and wait until the timer finishes counting down before turning back on
3.Save settings
4.Minor adjustments can be made on the GUI if necessary
Via GUI
1.Set RSSI min to zero and RSSI max to 255 and write
2.With TX off, increase RSSI min and write. Repeat until OSD reads 0% consistently
3.With TX on, decrease RSSI max and write. Repeat until OSD reads 100% consistently
this video will help many with on screen config
https://www.youtube.com/watch?v=pd_PXnG_PkI
Last Edit: August 01, 2014, 12:55:08 AM by Martink1974
Reply #25 on:
August 01, 2014, 10:37:55 AM »
Quick vid showing mw-osd in action
Used this flight to calibrate virtual current sensor
It's way out in vid but does work pretty well now
https://www.youtube.com/watch?v=QBYFYbscE04
Last Edit: August 01, 2014, 10:40:19 AM by Martink1974
papa_lazerous
Reply #26 on:
August 01, 2014, 11:10:50 AM »
I was messing with my osd firmware last night I went back to kv osd 2.3 with the large font as I'd only tried it with small before. Quite happy with that, but figured I'd go back again to mw osd firmware and when I did I get nothing on the osd only my video. Probably something stupid couldn't find out what it was last night though. Thinking I might need to erase the eeprom to be safe. Anyone else had this issue?
Reply #27 on:
August 01, 2014, 11:26:02 AM »
At one point I had a similar weird problem, I tried kv EPROM thing to no, wish I could say what got it working but I was messing in mw config tool when it started working again , maybe pal NTSC settings not sure , I'll post screen shot of what works if no joy , a little mad really I messed for an hour, Ben had problem maybe he could comment if he knows what fixed it other than witchcraft
papa_lazerous
Reply #28 on:
August 01, 2014, 11:39:58 AM »
I probably did miss something like pal NTSC it was late and I'd had a beer. Will look again tonight but other than that I'm not sure what it could be as I've had it working before
papa_lazerous
Reply #29 on:
August 01, 2014, 09:37:57 PM »
I got everything running again, I did have it set on NTSC like a numpty
Pages:
2
3
Equipment
Video Equipment
Guests: 41
Users: 4
cubizen
Propellers 15" 17" DFDL, Turnigy, RCTimer CW CCW Multirotor Propellers CHEAP !
Mancini
at 09:12:24 PM]
Mobius lens A
at 10:59:38 AM]
DJI iOSD Mini - £30
CX-20 RTF Quadcopter **MINT**
