  • Mini craze
Pages: 1 [2] 3 4 ... 6
Author Topic: Mini craze  (Read 3980 times)
Re: Mini craze
« Reply #15 on: April 13, 2014, 12:26:48 PM »
Mini First 1
Second flight (first one out doors). Difficult to fly in front of the camera, and try to fly around at the same time.
This one will easily fly until the battery is dangerously low, think it needs voltage monitoring in flight or your going to damage batteries...
Re: Mini craze
« Reply #16 on: April 13, 2014, 07:34:19 PM »
3amp is very very good, had mine in the garden before with 2 bladed props and they have plenty of punch, I didnt have vtx on so a little more weight to be added. I will be using a hobby King simple voltage OSD for mine as I have one knocking around. Zero Jello from mobius too, will get video up shortly.
Re: Mini craze
« Reply #17 on: April 13, 2014, 10:34:25 PM »
yes a simple voltage osd would be perfect! think I have a knackered one here somewhere, must have a look at it!
No jello, that's good news! still thinking whether to modify the quad or sell it and make my own slightly larger quad frame, say 330mm.
Flew mine on manual and landing was worse than with self leveling on! keeps bouncing back in the air! still on default settings though...
Re: Mini craze
« Reply #18 on: April 13, 2014, 10:35:25 PM »
Gusty as hell, but she flies :)
Spanky Maiden
Spanky Mobius Maiden (Jello Test)
FPV gear all wired up now, even squeezed blue tooth on it, tidiest wiring job i ever done too! Will take some pics when i get better light.
« Last Edit: April 13, 2014, 10:38:13 PM by MrBen »
Re: Mini craze
« Reply #19 on: April 13, 2014, 11:15:09 PM »
looks like its well under control, ideal for flying in and out of buildings/trees and landing was good!
These little motors have bags of power don't they! I might just bung 1.2 on it, and see what size video battery I can get away with!
Re: Mini craze
« Reply #20 on: April 23, 2014, 10:18:35 PM »
Batteries finally arrived today and it balances perfect. AUW is 550g fully loaded. Now if I could only get this uhf rx to bind!
Re: Mini craze
« Reply #21 on: April 23, 2014, 10:27:34 PM »
nice and tidy, whats going on with the ezuhf?
Offline ady.g.
Re: Mini craze
« Reply #22 on: April 23, 2014, 10:45:31 PM »
very neat.
I FLY mini's very badly (*_*)
Phantom F61 for the win twinstar in the bin.
Re: Mini craze
« Reply #23 on: April 24, 2014, 06:23:10 AM »
cheers guys, just wont bind, will have a play later
Re: Mini craze
« Reply #24 on: April 25, 2014, 04:46:07 PM »
Done a bit more initial testing this time with two bladed props! currrent at hover 3.2 amps, actually at bit too close to the previous 3A on 3-blades, I'd say that the current taken is roughly the same!
Full throttle this time was 20Amp, quite a bit more than the 3-bladed props, Didn't (couldn't) measure thrust and the top rpm is certainly to be much higher...
Re: Mini craze
« Reply #25 on: April 29, 2014, 10:09:35 PM »
Did some basic tests on the mini hex, weight ready to fly with 1300 mAh battery 464 gram
Current at hover 5A
Current full throttle 29A
Props used 5X3 two blade
Re: Mini craze
« Reply #26 on: April 29, 2014, 11:09:27 PM »
This is the first chance I've had to compare different layouts using the same components.
The measurements alone are pretty useless, but used as a comparison, I'd say there is a strong indication that the hex layout is less efficient system than a quad! in fact following that reasoning, the octo would be the least efficient!
Although I haven't tested further, it would also point to a tricopter possibly being more efficient, and a conventional single rotor helicopter as the most efficient!
So apart from the "impress your friends - I've got an Octo viewpoint" the best route I would take is, want more lift then use bigger motors and props on your quad!
Re: Mini craze
« Reply #27 on: May 15, 2014, 12:12:28 PM »
Took the mini hex out for a spin, Landed lightly in grass but it took a tumble, everything ok then went on and used up two more batteries flying around! Only when sticking it back in the boot I noticed one prop spinner was missing! Being self tightening threads I imagine it came off in the tumble (probably came to a quick stop in the grass). Unbelievable that the prop not only stayed on the motors but worked flawlessly as well!...
Re: Mini craze
« Reply #28 on: May 19, 2014, 10:39:40 PM »
heres my latest mini with mods etc..453g rtf..
Re: Mini craze
« Reply #29 on: June 15, 2014, 02:03:02 PM »
Here's my spanky,
Done a couple of flights LOS, still sorting out pids on the multWii FC
Shown here with vtx and mobious just laid in place, agree with the 500g target, motors are hard worked but capable! First time using the multiwII so a lot twiddling pids ahead
« Last Edit: June 15, 2014, 02:12:08 PM by bigMouse »
  • Mini craze
  • Dot Guests: 32
Page created in 1.067 seconds with 23 queries.
