  • Mini craze
[Today at 08:16:48 PM]
[Today at 06:09:36 AM]
[Today at 06:09:29 AM]
[Today at 04:40:58 AM]
[Today at 04:10:41 AM]
Pages: 1 ... 4 5 [6]
Author Topic: Mini craze  (Read 3979 times)
Re: Mini craze
« Reply #75 on: October 15, 2014, 10:28:58 PM »
I built one of those for my mate it flys pretty well but its not quite square its wider than its long does not make much difference I spaced plates out using only 2 holes for each leg and used spanky anti vibes mounts , works well considering he is using cheap props, ill try n find pics on my phone
« Last Edit: October 16, 2014, 07:45:08 AM by Martink1974 »
Re: Mini craze
« Reply #76 on: October 15, 2014, 11:42:29 PM »
Yes I see what you mean! Could make new bottom plates and stagger the legs more!
I'm am a bit surprised that the frame is quite rigid.
I'm low on spare motors now so can't see it being fitted out for a while.
Re: Mini craze
« Reply #77 on: November 09, 2014, 06:40:57 PM »
I decided to push on and build this little quad for 4S!
Biggest problem was how to achieved a reasonably clean build! The gap between the two lower plates that clamp the arms is not only too narrow, but long enough to accept two esc's per side either. Finally decided on ESC's half inboard, half on the arms!
Ther PDB is on top of the upper plate, think it turned out quite neat under the circumstances!
« Last Edit: November 09, 2014, 06:46:00 PM by bigMouse »
Re: Mini craze
« Reply #78 on: November 09, 2014, 06:45:24 PM »
Motor leads were soldered direct to the ESC's, gap between motor and ESC 50mm
Tied a know in the motor wires to make it easier to adjust length
Re: Mini craze
« Reply #79 on: November 09, 2014, 06:47:36 PM »
To get access to the PDB mounting screws, opened out the lower plate holes to 6mm to clear the screw heads
Re: Mini craze
« Reply #80 on: November 11, 2014, 01:07:26 PM »
Looking good, proper clean build . Are you going for 4s on the days motors ?
Re: Mini craze
« Reply #81 on: November 11, 2014, 04:57:36 PM »
yeah these frames are tight as hell for space down the bottom. Since I just tore mine down I had a bag full of prop centres for the twinstar all different sizes I sourced 16 that fit snug over the bolts and used them for spacers on the arms since the bolts are long enough. gave me an extra 5-6mm between the bottom plates and saves me grinding the thread of the bolts on gravel landings. The bolts sit flush with the end of the nuts now :)
Re: Mini craze
« Reply #82 on: November 11, 2014, 05:11:27 PM »
Quote from: bigMouse on November 09, 2014, 06:47:36 PM
The frame i just got has these holes for the ali posts. Good job s i forgot to install them befor bolting bottom 2 plates together. Well ill be striping it all down again to fit new esc anyway
Re: Mini craze
« Reply #83 on: November 11, 2014, 07:21:22 PM »
Yes must admit it is a pretty tight build (hard to make a clean installation!)
This the frame complete less top deck. Weight of what you can see is 339 grams
1300mAh 4S nanotech and top plate appx 160 grams ( Mobious and vtx to account for)
Gav, Yes 4S, but will test on 3S/4S with 5X3 and 6X3 props.
Re: Mini craze
« Reply #84 on: November 11, 2014, 08:00:55 PM »
why the knots in the esc/motor wire?
Re: Mini craze
« Reply #85 on: November 11, 2014, 08:09:46 PM »
Quote from: xxpitt on November 11, 2014, 08:00:55 PM
Probably cos the DYS motor wires are super long. I just cut and soldered them directly to the esc's on mine.
Re: Mini craze
« Reply #86 on: November 11, 2014, 08:25:12 PM »
The knots were to save a bit of wire length! If I later fit these motors on another frame there should be enough wire with the knots undone, to move the ESC's inboard.
Re: Mini craze
« Reply #87 on: November 12, 2014, 11:59:49 AM »
[/quote]
Cool will be good to see how they do on 4s
Re: Mini craze
« Reply #88 on: November 12, 2014, 06:23:38 PM »
Only hover testing due to high winds and rain. Tested on 3S and 4S using 5X3 props.
Using similar config to Spanky, this one is behaving totally different, major high speed wobbling in horizon and in acro, so need some lengthy testing I think!
First problem arises from the short distance of the front to rear motors, obvious main effect is that it makes fore/aft balancing much more critical. I will continue testing this frame although already redesigning the bottom plates to get more spacing!
  • Mini craze
  • Dot Guests: 34
  • user kc7rqa
[Today at 12:33:18 AM]
Page created in 0.845 seconds with 22 queries.
