  • MrBens Zephyr XL Build Log
[Today at 08:26:01 PM]
[Today at 12:52:16 PM]
Pages: [1] 2 3 ... 5
Author Topic: MrBens Zephyr XL Build Log  (Read 6710 times)
« on: April 09, 2013, 08:54:20 PM »
First job sand down wing join and glue together, UHU Por on the surface and CA glue on the crack afterwards
Next I need to enlarge both the front lipo bay and the rear RVOSD bay you can see the difference between stock size and enlarged size on the next 2 photos
The very front of the lipo bay will be completely cut away later once a new battery bay/cam box has been made from ply, this will run right through to where the nose of the aircraft currently is and will be one piece. I will line the floor of the RVOSD rear compartment with 1mm fibre glass sheet
« Last Edit: April 09, 2013, 09:02:11 PM by MrBen »
Re: MrBens Zephyr XL Build Log
« Reply #1 on: April 09, 2013, 09:11:03 PM »
Next step to join the wing halves and add the main spars
There are 2 spars stacked in the groove, the first is CA'd in place then coated with a line of gorilla glue which is then activated with water, next the 2nd spar goes in on top of the GG and held in place with loads of T pins, be careful at this point as it can easily start pushing the spar out of the slot! The T pins did the job and held it firmly in place :)
Once the GG has stopped expanding I removed the pins and added some more GG to fill the void
And once it is 80% dry it can be trimmed off with a sharp knife
« Last Edit: April 09, 2013, 10:42:34 PM by MrBen »
« Reply #2 on: April 09, 2013, 10:43:36 PM »
Now I added 2 spars on the top fore and aft of the back bay
« Reply #3 on: April 10, 2013, 03:05:51 AM »
looking good
« Reply #4 on: April 11, 2013, 06:36:39 PM »
Just a result of some searching, Take it with a pinch of salt, I have no first hand knowledge of the stuff!
Warning about using 3M77
[url]http://fpvlab.com/forums/archive/index.php/t-179.html?s=ee26390ee478688454ba9341b1ba9b49]http://fpvlab.com/forums/archive/index.php/t-179.html?s=ee26390ee478688454ba9341b1ba9b49]
[url]http://fpvlab.com/forums/archive/index.php/t-179.html?s=ee26390ee478688454ba9341b1ba9b49[/url]
Suggested replacement for 3M90
http://www.loctiteproducts.com/p/a_cntct_high/overview/Loctite-Spray-Adhesive-High-Performance.htm
Might be able to get that locally, save postage...
« Reply #5 on: April 11, 2013, 06:40:34 PM »
Think I might go with 4 servos, Borrow them from an old f3J . They are hs81mg's
Ben, Are you going to paint the foam or add vinyl over the Lam?
« Last Edit: April 11, 2013, 06:44:19 PM by bigMouse »
« Reply #6 on: April 12, 2013, 12:39:45 PM »
Just received mine Ben, thanks for your efforts!
Will go with the OS 750kv choice, need to make it quiet as possible, 3, 4S Haven't decided yet, will try both...
« Reply #7 on: April 12, 2013, 05:01:44 PM »
Cant find that loctite 200 anywhere in the UK, Just ordered some more tesa although I'll do lighter coats this time so I dont get any pitting, gonna send the 3m77 back.
http://www.amazon.co.uk/dp/B002BDPI8I?tag=tesa0a-21&camp=1406&creative=6394&linkCode=as1&creativeASIN=B002BDPI8I&adid=0EQGKJ71G10R1KH623N6&&ref-refURL=http%3A%2F%2Fwww.tesa.co.uk%2Findustry%2Fspray-glues%2Fextra-strong-glue%2Fextra-strong-spray-glue%2C2488081%2C1.html
Also ordered a selection of props to try with the OS 750
 APC 11x7 Thin Electric Prop
 APC 11x8.5 Thin Electric Prop
 APC 12x6 Thin Electric Prop
 APC 12x8 Thin Electric Prop
 APC 13x6.5 Thin Electric Prop
 APC 13x8 Thin Electric Prop
« Last Edit: April 12, 2013, 05:03:36 PM by MrBen »
« Reply #8 on: April 13, 2013, 08:33:13 AM »
I haven't found a source either! Can't believe that spray glue is so elusive!
« Reply #9 on: April 13, 2013, 09:02:10 PM »
Motor mount gorilla glued in place
Prop opening enlarged to 13.5"
Servos moved to new forward wider location, all old servo holes filled with foam/gorilla glue. Everything has had a coat of light weight filler too.
VTX bay, UHF rx bay both cut into wings and cables running to centre compartment, wing joint and spars filled.
« Last Edit: April 13, 2013, 09:07:43 PM by MrBen »
« Reply #10 on: April 21, 2013, 09:12:16 PM »
Camera bay box made from 6mm ply, needs covering black or painting. Weighs 60g
Wing all laminated in 125micron laminate, wings were sprayed with Tesa extra strong spray glue first
RVOSD fitted, shielded wires running from VTX, that black wire is the ground for the shield, microphone on this bird too.
Getting there now, still got to add cam wire, ubec and esc, also add battery box from 3mm ply
At this stage it seems to balance ok with 3x 4s 3300mah in battery bay, thats with the OS 750KV motor in the outboard position, thats a 13" prop on her too.
« Last Edit: April 21, 2013, 09:22:35 PM by MrBen »
« Reply #11 on: April 21, 2013, 09:52:51 PM »
Looking very nice a sleek.
« Reply #12 on: April 21, 2013, 11:56:30 PM »
Looking nice Ben!
« Reply #13 on: April 22, 2013, 06:17:09 AM »
Cheers guys, will try and get it ready for a weekend maiden :)
« Reply #14 on: April 22, 2013, 08:18:13 AM »
nice job on the camera box..
  • user ap2
[Today at 07:17:14 PM]
Page created in 0.763 seconds with 21 queries.
