  • MrBens Zephyr XL Build Log
a wing and a prayer by xxpitt
[May 04, 2015, 09:35:34 PM]
[May 04, 2015, 07:42:23 PM]
Chasing mr.ben by bigMouse
[May 04, 2015, 04:40:29 PM]
[May 04, 2015, 04:39:10 PM]
Setting up a mix on taranis **HELP** by MrBen
[May 03, 2015, 09:12:39 PM]
Help :) :-) by bigMouse
[May 03, 2015, 10:03:21 AM]
Micro Minim OSD (MWOSD for Naze) by bigMouse
[May 03, 2015, 09:57:02 AM]
x5 maiden by xxpitt
[May 03, 2015, 09:48:59 AM]
[May 02, 2015, 07:43:10 PM]
[May 02, 2015, 06:19:07 PM]
Getting Back into it - FPV Spanky Callidus80 - Cobra 1960Kv by xxpitt
[May 02, 2015, 03:14:40 PM]
How to care for you lipos by bigMouse
[May 02, 2015, 08:48:13 AM]
New 250 FPV Racer by JUST CRASH
Limited Offer: FPVModel MC4012 340KV Motors Sold At $23.49 by fpvmodel
[April 29, 2015, 08:46:53 AM]
Pages: 1 2 [3] 4 5
Author Topic: MrBens Zephyr XL Build Log  (Read 6774 times)
Re: MrBens Zephyr XL Build Log
« Reply #30 on: April 30, 2013, 03:57:35 PM »
Quote from: brodjackella on April 29, 2013, 08:08:04 AM
cofg too far back usually comes with nose diving down with slightest down elevator and hard to fly level and land,especially into wind.Could be weak servos or loose control rods also.
sure could tell on video which way wind was blowing.lol
servos have 7kg torque Im using HS645MG, there is zero slop in the control linkages but a tiny bit on the servo arm itself, I have minimised the  effect this has by moving the pushrod to the hole closest to the servo, I asked Mark to check my old zep2 and he said there was a little bit on that one too which is pretty much the exact build of this (I sold my old one to him)
« Reply #31 on: April 30, 2013, 03:57:59 PM »
Quote from: chrisallen649 on April 29, 2013, 01:58:39 PM
was this the first atempt or second mate?
3rd :)
« Reply #32 on: May 01, 2013, 06:32:40 AM »
Quote from: bigMouse on April 30, 2013, 01:20:36 PM
Ben, I believe your using single Elevon's, are your servos adequate?, slop in linkage??
That's the only thing I can think of that might cause that...
Filled mine yesterday, sanding down then spray glue today, Paint tomorrow, might be ready by end of week, maybe...
What weight Lam did you use on the Elevon's?
I used 3mil (75micron) on the elevons, I think the servos have enough power as they have 7kg torque, plus it does it at all speeds
Latest video has a preflight look at the plane and a post flight analysis
zxl4thflight
« Reply #33 on: May 01, 2013, 07:52:48 AM »
No slop to worry about in that linkage!
The wide angle lense is distorting the wing shape, can't tell if those vertical stabs are upright or leaning out as per build videos.
Is the bobbing up and down visible from the ground! I mean is it subtle or really obvious large movements?
The only difference with yours and the ritewing video example is the wider opening at center to accept the 13" prop, and one servo per elevon, neither of which should cause anything like your experiencing!
« Reply #34 on: May 01, 2013, 07:41:33 PM »
Final flight of the Zephyr XL
Zephyr XL splits in mid air : Gopro footage
« Reply #35 on: May 01, 2013, 08:26:35 PM »
bad luck Ben, that's proper shitty mate.
did you find the current sensor and batteries?
You could see it starting to wobble up and down just before it tore apart.
« Reply #36 on: May 01, 2013, 08:37:56 PM »
shame ben was a sweet looking wing,scary to think that something like this can happen so quickly and before you know it you have no plane .
« Reply #37 on: May 01, 2013, 09:00:06 PM »
this might have happened http://www.youtube.com/watch?feature=player_detailpage&v=aZQlmxrmjXQ#t=114s
« Reply #38 on: May 01, 2013, 09:06:09 PM »
Damn it ! That's a real shame mate ! Wonder what happened ?
I studied that bridge as part of my degree - not really flutter but simple harmonic motion - ant the geek !
« Last Edit: May 01, 2013, 09:08:16 PM by Ant »
« Reply #39 on: May 01, 2013, 09:13:03 PM »
no, i mean later in the vid.
at 2.25 it's almost exactly what could have happened to the ZXL
« Last Edit: May 01, 2013, 09:14:52 PM by CorporalB »
« Reply #40 on: May 01, 2013, 09:13:32 PM »
Ben, I'm really sorry about this! Hopefully it can go back together!
Looked like severe flutter to me!. Think I'll do my first test without the vertical stabs, they might be resonating with the larger prop! Can you remember if it porpoised with the throttle cut?
« Reply #41 on: May 01, 2013, 09:32:13 PM »
it still did it with throttle cut and that last flight was without the vertical stabs
« Reply #42 on: May 01, 2013, 11:13:46 PM »
Quote from: CorporalB on May 01, 2013, 08:26:35 PM
current sensor was recovered, one of the batteries was found burnt out and the other 2 lost, everything else recovered and working including rvosd :)
« Reply #43 on: May 02, 2013, 12:34:30 AM »
Bummer
I assume whatever the cause it was something to do with the nose bobbing and the fluttering
Know how you feel Ben, my latest pride and joy (Sport Jet on 5 cell) now looks like it's a 3 year old beat up plane
« Reply #44 on: May 02, 2013, 07:37:38 AM »
If we can apply some constructive criticism, you seemed to be giving it some wellie! at least for a wing it seemed fast from the video! As an example, on my Vega to make it go faster than it's happy maximum, say 40mph. takes a load of amps, you were flying more or less straight when it looked as though the entire wing had gone into some kind of flutter/resonance. The center section on the zep's is the weakest area, almost entirely battery bay cut-outs, would suggest they need more reinforcement. Perhaps the cause of the original problem was the entire wing twisting, rather than just the control surfaces. Going back in history, the Horten wing suffered the same fate! Long slender wings were never rigid enough in flight, Some of their beautiful high aspect ratio designs never left the drawing board. Probably need to limit the speed, and add reinforcement (or use a  lower aspect ratio as in the zII)
Pages: 1 2 [3] 4 5
Page created in 1.23 seconds with 22 queries.
