  • KK2 board with autolevel under £20
Flyingwings Venturi Evo build by Quagmire
[Today at 12:39:44 AM]
Happy Flyers on tour Part 1 - Millau Viaduct FPV with nasty surprise by xxpitt
[May 31, 2015, 11:09:03 PM]
1.2ghz by bigMouse
[May 31, 2015, 10:28:40 PM]
What did the postman bring you today? by gavnthat
[May 30, 2015, 01:59:42 PM]
[May 29, 2015, 10:38:24 PM]
[May 28, 2015, 04:31:42 PM]
Spanky 5 Action by gavnthat
[May 27, 2015, 09:39:49 PM]
FPV Racing Rear View Camera Action by MrBen
[May 26, 2015, 05:38:40 PM]
[May 25, 2015, 08:01:49 AM]
FPV in the sunshine :) by xxpitt
[May 24, 2015, 10:44:17 AM]
[May 23, 2015, 06:49:03 PM]
Park Life by Martink1974
[May 23, 2015, 10:23:59 AM]
GemFan killers: DragonFly Bulletproof propellers for Mini Quads by Dan
[May 27, 2015, 01:11:00 PM]
[May 20, 2015, 05:48:31 AM]
New 200mm Mini Quadcopter RTS200 by fpvmodel
[May 18, 2015, 03:31:25 AM]
Pages: 1 2 [3] 4 5 ... 11
Author Topic: KK2 board with autolevel under £20  (Read 20628 times)
Re: KK2 board with autolevel under £20
« Reply #30 on: July 24, 2012, 12:18:09 PM »
downloaded the H Quad build video from flite test last night (internet is too slow here to stream) will watch it tonight, but looks really easy. much easier than the old X quads I used to build.
« Reply #31 on: July 24, 2012, 05:22:18 PM »
Think I might get one of these to use on the grasshopper as Im going to be teaching my lads to fly it, I think it will make things easier for them. I wonder when Hobby King UK will have them ?
« Reply #32 on: July 24, 2012, 07:53:50 PM »
Yeah, I havent been able to find a thread where someone used one of these FCs for a fixed wing yet. Would be interesting to see how good the stabilisation would be. real simple too. When armed, the gyros will combat any unwanted movement from external forces, flick a switch and it auto-levels. the designer kaptainkuk has confirmed that it will auto-level a fixed wing ac.
« Reply #33 on: July 24, 2012, 10:15:57 PM »
oh yeah, look what arrived at home. all the parts are there now, my lovely wife just needs to send them down and I can start building :)
« Reply #34 on: July 24, 2012, 10:57:26 PM »
I've got mine too, not read any manuals yet...is that a buzzer that comes with it? Where does that plug in?
« Reply #35 on: July 25, 2012, 12:56:46 PM »
Yes Steve, it has a low voltage alarm built in too. it plugs into the piezo output pins labelled in the top right of this picture:
« Reply #36 on: July 25, 2012, 01:03:25 PM »
Ah thanks. Hoping to start rebuilding my quad tonight using it. Read yesterday that firmware on it was tested with simonk flashed escs so settings need tweaking for standard escs.
« Reply #37 on: July 25, 2012, 02:02:47 PM »
flashed escs? ffs, yet another thing people are messing around with eh? why make everything so complicated lol
Offline micarus
« Reply #38 on: July 26, 2012, 01:45:03 PM »
Hi, have just built my KK2 " Spider "quad and all motors are running ,all controls going the correct way  but can't get it to settle down even though I'v reduced all the gains and tried it on low rates on my DX6i? :-\
Have had it off the deck but only for a second ! :o
 I have my S/L on the gear switch and when I try that it is even worse! ::)
       Running out of ideas, and suggestions welcome.
                  Cheers   MIKE
« Reply #39 on: July 26, 2012, 01:55:10 PM »
Mike, have you seen all the various documents that are on the files section of the HK KK2 board site?  Especially the one I mentioned above about the boards being tested on flashed speed controllers, which radically alter the suggested settings on the board itself.  I've also seen a video of a guy setting up a tricopter who says his figures are no-where near stock.
I haven't built mine yet (was hoping to do it last night but ended up playing with my new OSD instead) so can't offer any first hand experience yet.
Will be interested if you figure it out, be great to share our findings on here.
Edit - here's the link http://www.hobbyking.com/hobbyking/store/uploads/310116513X61437X40.rtf
and http://www.hobbyking.com/hobbyking/store/uploads/475200704X68736X56.pdf
« Last Edit: July 26, 2012, 02:13:59 PM by Balders »
Offline micarus
« Reply #40 on: July 26, 2012, 03:42:06 PM »
Thanks for the reply Balders, I have downloaded the doc's and will study them and put the results up when I sort it out <and pic's>. ::)
       Cheers m8,   MIKE. ;D
Offline micarus
« Reply #41 on: July 27, 2012, 09:16:14 AM »
Hi Balders , Tried all sugested and all the different settings posted by Katainkuk but it's still as mad as a box of frogs  :'( <doin' my head in> , I thought this was supposed to be easy ! but it's not. ::)
             Cheers   MIKE. :(
« Reply #42 on: July 27, 2012, 09:20:21 AM »
I got mine hooked up to my quadlet last night, only had a quick play with it (it was getting late) and didn't feel comfortable.  One motor seemed to be spinning up much more than the others (note I had props off).
When I went to bed I re-read the manual, and I think I know where my problem possibly stems from.  I sort of skipped one of the setup steps, which says ensure that by using trim/subtrim, all the centre values displayed on the LCD are zero.  I'm pretty sure when I was messing around they weren't all exactly zero, which I guess could explain the motor spooling higher than the others, trying to make an input that isn't there, and as it was sat on the floor, it just gets worse as it tries to compensate.
What exactly is the symptoms on yours?  I'll be playing with my settings a lot more tonight whilst the wife watches a load of shellsuit wearing people walk around a large circle.  Something going on in the UK apparently.
« Last Edit: July 27, 2012, 10:04:56 AM by Balders »
Offline micarus
« Reply #43 on: July 27, 2012, 07:13:36 PM »
Glad to hear you are starting to sort yours out Balders , mine fires up ok but when I get it to take off revs it is too aggresive and tries to either flip forward or flip sideways! it is obeying the transmiter as far as inputs are concerned but way to fast for me even with realy low rates. :'(
I dont know exactly what the difference is from "P" and "I" as the destuctions don't say, If you set the  "P" rates too low there don't seem to be any corection , too high and it goese wild ! ::)
See what you think mate I'm off to wach C.S.I as I need a break from the darned thing now! been at it for hours> >:(
                         Cheers  M8,    MIKE. :)
« Reply #44 on: July 28, 2012, 11:12:44 AM »
OK mate, as I start to tinker and understand mine more I'll post my findings.  From what I can gather I think P is a sort of pitch correction, so if you tilt it forward for forward flight, it neither gains nor loses altitude so you don't have to correct pitch on the throttle.  Think of it as the balance between front and rear props. It rears just sped up and front remained the same, it'd gain altitude and vice versa.
  • Dot Guests: 49
  • user carlr
Genuine Alexmoss 3 axis Controller build on one board. by Mancini
[May 17, 2015, 01:08:32 AM]
Page created in 0.451 seconds with 22 queries.
