  • Other »
  • CNC Routing & 3D Printing »
  • FPV Related 3D Prints
Pages: 1 [2] 3 4 5
Author Topic: FPV Related 3D Prints  (Read 1557 times)
Re: FPV Related 3D Prints
« Reply #15 on: December 24, 2014, 10:37:36 AM »
This is my own design lens cap replacement (always losing mine!), Not as pliable as the original so needs to be printed at exact size! Bright colour is more difficult to lose!
Material PLA
My nozzle size: 0.4mm (compensate for different nozzle sizes!)
Extruder: !st layer 210c, following layers 190c, bed temp 60c
Initial layer thickness: 0.3mm
Layer Height: 0.1mm
Bottom layer speed 20mm/s
Print speed: 50mm/s
Fill Density: 100%
Top & bottom thickness: 0.8mm
Enable Combing
Cooling fan enabled 100% at 0.5mm Height
Pictures below show that it fits a range of cameras, from small, to seaWolf
« Reply #16 on: December 24, 2014, 10:00:59 PM »
Just tweaked a little bit these designs:
http://www.thingiverse.com/thing:410648
http://www.thingiverse.com/thing:286251
http://www.thingiverse.com/thing:165751
http://www.thingiverse.com/thing:512434
To make a good little mounting setup for the 250mW Tx and FatShark 600TVL CMOS camera that are included with the Predators V2. The stl. file has both Tx mount versions as I haven't printed them out yet and don't know which is better. Added some more mounting holes and added to the camera mount. The Tx mount and camera mount can clip together to make it easy to throw on a quad all at once but is easy to seperate if there is more room for Tx elsewhere on frame. In the remixes in the 3rd link there is an improved model of the FatShark 600 TVL CMOS camera if anyone wants to use it to make their own mounts with it.
NOTE: I do not take credit for the creation of these pieces only tweaking them. These files were uploaded by the various users in the above links, and each has their own specific Creative Commons licence pertaining to the files. Before using their files or these modified files check their licences to know what rights you have pertaining to usage and distribution of the files.
« Reply #17 on: January 15, 2015, 08:08:29 PM »
ZMR 250 gopro mount with anti jello lower plate
http://www.thingiverse.com/thing:596799
« Last Edit: January 15, 2015, 08:34:55 PM by MrBen »
« Reply #18 on: January 19, 2015, 11:04:39 PM »
Think im going to be needing one of those gopro zmr mounts, ill have to tweak it to point up though.
This is a nice feature for the zmr.
Motor mounts to tilt the motors like the Gemini,
spacers for the bottom two plates so you can mount PDB and ESCs between,
and a spacer for LEDs.
http://www.rcgroups.com/forums/showpost.php?p=29918506&postcount=215
« Reply #19 on: January 20, 2015, 10:09:17 AM »
I've got a spare zmr frame here, might make another 4S version!
Probably will make spacers etc, tuck away the ESC's! see how it turns out!
« Reply #20 on: February 04, 2015, 05:55:07 PM »
Made a little FPV backpack for Cobs ladybird, there is another part printing now that clips it onto the frame
Offline Cobs
« Reply #21 on: February 04, 2015, 05:59:35 PM »
Assembled before your very eyes :)
Very neat fit indeed Ben
« Reply #22 on: February 04, 2015, 06:01:32 PM »
That's mint Ben don't suppose you accidentally did an extra one  did you ? Lol
« Reply #23 on: February 04, 2015, 06:03:12 PM »
still tweaking it but will do you one too, which bit gets hot on the vtx? is it the large casing on the vtx module itself? I have put a hole underneath but its still 50% covered so may rethink it a little
« Reply #24 on: February 04, 2015, 06:06:51 PM »
this is the clip, I printed it in 2 pieces as it will be 20x stronger this way, if it was one piece then the clip would certainly de-laminate on the layers running across, this way the layers run up the clip
« Reply #25 on: February 04, 2015, 06:49:00 PM »
Nice one Ben!
« Reply #26 on: February 04, 2015, 06:50:20 PM »
cheers BM but these are pretty easy designs to knock up, I wouldnt know where to start with something like the hydroplanes!
« Reply #27 on: February 04, 2015, 07:57:19 PM »
here it is, version 1, its a WIP, need better cooling for VTX module (I guess) and also it can slide forward and back a few mm so will make the clip bigger
« Reply #28 on: February 04, 2015, 07:58:00 PM »
Quote from: MrBen on February 04, 2015, 06:03:12 PM
Not sure which bit gets hot but its the side with the dip switches on, wouldn't worry too much I have heatshrinked mine completely and sealed one end and it still OK.
Offline Smit80
« Reply #29 on: February 04, 2015, 08:00:24 PM »
Quote from: MrBen on February 04, 2015, 05:55:07 PM
Omg Ben thats Epic!
Pages: 1 [2] 3 4 5
  • Other »
  • Dot Guests: 46
  • user CAMOMAN
Page created in 0.995 seconds with 21 queries.
