  • Mini APM in a X5 Flying Wing
THuG Props (AIRSCREWS) by Martink1974
[June 27, 2015, 11:36:27 PM]
[June 27, 2015, 10:53:10 PM]
[June 27, 2015, 07:04:32 PM]
Weston Park 2015 Nano Air Gate Practice by JAB1a
[June 27, 2015, 11:01:53 AM]
Weston Park by Martink1974
[June 26, 2015, 07:38:16 PM]
Walkera Runner 250 FPV Racer - Video by MrBen
[June 26, 2015, 04:22:46 PM]
Losi 5ive-T maybe for FPV - see how it goes by bigMouse
[June 25, 2015, 08:02:37 PM]
Taking FPV to the Sea by Cobs
[June 24, 2015, 08:42:04 PM]
Best antennas - Original vs Generic by xxpitt
[June 23, 2015, 09:26:29 PM]
250 Flight Times by MrBen
[June 22, 2015, 06:26:01 PM]
DJI Inspire 1 Maiden by MrBen
[June 22, 2015, 06:24:38 PM]
DIY Head Tracking for Cheap by matoil
[June 22, 2015, 06:06:10 PM]
Dan's place :) by Callidus80
[June 22, 2015, 10:14:24 AM]
Our Best Finds :) by bigMouse
[June 20, 2015, 09:34:42 PM]
Close Proximity FPV Leat flying by bigMouse
[June 17, 2015, 09:12:27 AM]
This is the best monitor we've ever used for FPV by myrcfpv
[June 18, 2015, 04:17:22 PM]
BNF 250 quadcopter by JUST CRASH
[June 13, 2015, 02:14:06 PM]
MFD Automatic Antenna Tracker control by myrcfpv
[June 10, 2015, 01:44:26 AM]
FPVMODEL RaceGates by fpvmodel
[June 09, 2015, 07:46:34 AM]
Pages: 1 2 3 [4] 5
Author Topic: Mini APM in a X5 Flying Wing  (Read 2476 times)
Re: Mini APM in a X5 Flying Wing
« Reply #45 on: October 23, 2014, 07:03:10 PM »
whoop ppm working :)
will hook up servos and motors next see if I can get them moving as they should!
« Reply #46 on: October 23, 2014, 08:10:22 PM »
I cant seem to get any movement from servos I have done the wizard, my stick movements on the TX show on the calibration screen on mission planner
I have conected the esc signal to M1 and the servos to A0 and A1
« Reply #47 on: October 23, 2014, 08:46:22 PM »
I think the servos go on the outputs same as the ESC if you look at the APM setup it has the servos to m1 and m2 and ESC to m3 don't think APM cares if its a motor or servo it is just sending a control signal. So in elevon mode this should be right servo m1 left servo m2 and ESC m3 looking from the back of wing.
« Reply #48 on: October 23, 2014, 09:04:17 PM »
sweet that works, elevons arent moving as they should but motor spins and things ARE moving, I guess I need to choose delta wing somewhere
« Reply #49 on: October 23, 2014, 09:21:34 PM »
Right seems that the APM doesnt do elevon mixing as standard in manual mode (but it will control it as elevons when a stabilized mode is activated)
However it is possible to set it up to do the mixing in manual mode too if I knew how to enter these commands :)
http://plane.ardupilot.com/wiki/arduplane-setup/first-time-apm-setup/reversing-servos-and-setting-normalelevon-mode/#New_style_elevon_mixing_EEPROM_setup_ELEVON_OUTPUT_option
« Reply #50 on: October 23, 2014, 09:39:46 PM »
I must have used the (really) old style elevon mixing as I was flying elevon a few years back, that was before a comprehensive manual was available! I seem to remember that I had manual elevon mix, (in manual, signal passes straight through the apm untouched)
There were DIL switches to select elevon mode!  In stabilise mode apm intercepts the signals and modifies them accordingly, I know I had mess around to get the right sense to the servos, but sorry, can't help with the modern version of ArduPlane
« Reply #51 on: October 24, 2014, 07:43:30 AM »
Quote from: MrBen on October 23, 2014, 09:21:34 PM
Those aren't commands Ben, they're simply parameters in the parameter list
You can change them using APM Planner
I've never used APM on a plane so my knowledge of it is very limited but I have set up countless on multi's
« Reply #52 on: October 24, 2014, 08:28:58 AM »
Tecnic beat me to it lol yeah plug APM in go to configuration tab at top and then advanced parameters on left side scroll down and you will see rc1-rev rc2- rev and elevon_output to get the servos moving in right directions. Think its just a case of trial and error to see which combination works, then it should mix the elevons in all modes.
« Last Edit: October 24, 2014, 08:36:43 AM by gavnthat »
« Reply #53 on: October 24, 2014, 05:06:39 PM »
Right gonna have a bash at that tonight then! Motor came today too, I have to cut new c-clip slot and reverse shaft
« Reply #54 on: October 25, 2014, 06:19:37 AM »
Right well I screwed up the motor by over tightening the grub screw when trying to get the last little bit of movement out of the shaft (after reversing the shaft and grinding a new flat and circlip slot), now the grub screw is completely rounded and stuck in, good job they are cheap as I'll just order another, this time from EU HK as they have the screw on prop adaptor in stock which means I dont need to reverse the shaft.
On a positive note the elevon mixing is working as it should in both manual mode and stabilized mode although I did have to reverse the elevator on my TX to get it right   :-\
Next job is hook up the GPS and try to get that working, I also just need to make a simple Cam/VTX/OSD harness.
« Last Edit: October 25, 2014, 07:43:38 AM by MrBen »
« Reply #55 on: October 25, 2014, 07:50:35 AM »
Weight without lipo is currently 655grams round that up to 700grams for bits and pieces not yet in like apm case some magnets to keep the canopy on etc. Also it requires a 375gram lipo to balance so looking at an AUW of a smidge less than 1.1KG
Just ordered a 3s 4000mah 40c turngy lipo and another motor  :D
« Reply #56 on: October 25, 2014, 08:00:23 AM »
cool should have plenty of power then with that motor Ben. was setting the elevons up pretty easy in the end ?
« Reply #57 on: October 25, 2014, 08:59:19 AM »
yeah m8 like you said in adanced config, couldnt find them without using the search function though
« Reply #58 on: October 26, 2014, 09:09:33 AM »
Well GPS is all wired up now, got it on the trampoline in the garden, currently has 9 sats and bad gps health message has gone :) GPS has slow flashing blue LED which Im pretty sure indicates a fix.
« Last Edit: October 26, 2014, 09:11:41 AM by MrBen »
« Reply #59 on: October 26, 2014, 05:34:38 PM »
Cool Ben but you know they're supposed to go side to side not upy downy ?
Pages: 1 2 3 [4] 5
  • user Hagar666
Lightbridge, Phantom, GoPro, Black Pearl by loganj13
[June 27, 2015, 07:38:15 AM]
Miniquad motors and escs! by loganj13
[June 27, 2015, 07:17:24 AM]
Page created in 1.018 seconds with 22 queries.
