  • Batteries & Chargers »
  • recommend a charger
20a sunrise slim esc by xxpitt
[Today at 02:58:09 AM]
Zippy Batteries and Charger Reccomendations? by loganj13
[Today at 01:15:21 AM]
Drone video with bikini model by BIRDS-EYE-VIEW.NL
[April 02, 2015, 05:34:55 PM]
Selling Up by bigMouse
[April 02, 2015, 11:49:45 AM]
[April 02, 2015, 09:47:09 AM]
FPV on a model race car by xxpitt
[April 01, 2015, 10:51:25 PM]
[April 01, 2015, 09:41:29 PM]
[April 01, 2015, 09:32:43 AM]
Affordable yet Quality FPV Quads? by xxpitt
[March 30, 2015, 08:06:09 PM]
anyone flying the weekend? by bigMouse
[March 30, 2015, 09:10:20 AM]
Complete beginner by bigMouse
[March 30, 2015, 08:56:23 AM]
All emax 250 owners cool site if you own a 3d printer by mark1975
[March 29, 2015, 01:17:19 PM]
Hi from Liverpool by xxpitt
[March 27, 2015, 03:48:23 PM]
MDC March 2015 Episode 2 - Cannons, Silver and Lambs by Cobs
[March 27, 2015, 04:38:59 AM]
VTOL by xxpitt
[March 26, 2015, 06:43:21 PM]
Author Topic: recommend a charger  (Read 1437 times)
recommend a charger
« on: February 17, 2012, 07:04:47 PM »
Hello fellow flyers,well as the title suggest I'm in the market to upgrade my charger the one I have at the moment isn't quite cutting it so my requirements are 3s and 4s mains powered just wanting to know the good ones out there your experiences etc .....cheers guys
Re: recommend a charger
« Reply #1 on: February 17, 2012, 11:07:37 PM »
I have this one and its awesome. http://www.giantcod.co.uk/icharger-208b-350w-balancecharger-p-404528.html
Its little brother is good too, and slightly cheaper.  http://www.giantcod.co.uk/icharger-206b-300w-balancecharger-p-405299.html
« Reply #2 on: February 18, 2012, 05:23:35 AM »
I use a hyperion duo
http://robotbirds.com/catalog/product_info.php?cPath=9_268&products_id=5877
Keeps me airbourne with just a few lipos as I can charge 2 at a time,
Offline Chris R
  • Mr Awesome
« Reply #3 on: February 18, 2012, 02:20:17 PM »
http://www.hobbyking.com/hobbyking/store/%5F%5F7028%5F%5FTurnigy%5FAccucel%5F6%5F50W%5F6A%5FBalancer%5FCharger%5Fw%5Faccessories.html
 http://www.hobbyking.com/hobbyking/store/%5F%5F7523%5F%5FTurnigy%5FAccucel%5F8%5F150W%5F7A%5FBalancer%5FCharger.html
both are excellent chargers :)
« Reply #4 on: February 18, 2012, 04:02:23 PM »
The 50W will struggle with anything 4s and up tho, wont it?
I know my 50w charger got very hot when charging 4s 3300s.
Offline Chris R
  • Mr Awesome
« Reply #5 on: February 18, 2012, 04:28:26 PM »
50w = 3.3a @ 4s. heat as never been a problem.
« Reply #6 on: February 18, 2012, 10:31:25 PM »
If you want to buy a charger and never need to upgrade then get yourself an iCharger 3010b  it's a 1000watt charger capable of charging upto 10s  I power mine off of 2 server power supplies in series (one has to be modified to stop a ground loop occuring)  I have setup for parallel and series charging depending on my requirments but have had it charging 6 packs at once in parallel using the full 1000watts and it worked like a charm.  Have got the temperature sensor for mine so I can attach it to the packs with an elastic band so the charger stops if it detects a problem with the temp, the charger can also check the internal resistance of packs which can be an early indicator of a cell thats failing
« Reply #7 on: February 18, 2012, 10:58:11 PM »
quite a few options there guys, helps alot thankyou
Offline Quagmire
    • SheldonHoly.co.uk
« Reply #8 on: February 19, 2012, 08:08:18 PM »
There is the £40 or so 100w one I have from Giantcod. Not that powerful, being 100w, but it has a built in power supply which is so much more convenient.
Built in power supply all the way, all the commercial power supplies are big and heavy so it's one less thing to carry and it makes the whole thing a LOT smaller.
Sheldon
Please, call me Sheldon.
« Reply #9 on: February 20, 2012, 01:48:12 AM »
I use quick UK charger cost about 60£ 3years ago ...it's perfect and still working nicely.Charging all my different lipo,Pb,Nimh,Nicd etc:.
but they stop doing them  :o
« Reply #10 on: February 20, 2012, 09:39:17 AM »
I have 2 x 50w imax chargers (they were only about £15) and more recently bought a Turnigy from hobbyking 150W which I use for my 6S 5000mah packs (although I used to use the two 50W at low amps...took a while!)  All three run off a server PSU in a briefcase so it's portable and I can charge 3 packs at a time without having to do any parallel charging etc.
recommend a charger
« Reply #11 on: February 20, 2012, 09:56:11 AM »
I'm amazed you guys are using such low power chargers... If want to charge six 3s 2200mah packs I can do all of them at once charging at 2c and have them all charged and balanced in about 40 minutes!  And that's 4.4amps per pack in parallel so times that by 6 and you have 26.4Amps which is around 330watts let's not even get started on charging multiple 4s or 6s packs. I have a second charger that can put up to 4A max into a 4s pack but it seldom gets used. Do you all get up at the crack of dawn to set everything charging or stay up all night before flying to charge up?
Sent from my iPhone using Tapatalk
« Reply #12 on: February 20, 2012, 11:06:35 AM »
Just have enough packs to do a session flying, then charge up when I get home. Never really been an issue for me.
recommend a charger
« Reply #13 on: February 20, 2012, 05:59:10 PM »
I normally take 5 different models and 4 to 6 packs each, I got allot of lipo's lol
  • Dot Users: 0
There aren't any users online.
wanting a few bits by lkparky
[March 28, 2015, 10:05:14 PM]
Mobius lens A by lkparky
[March 28, 2015, 09:56:37 PM]
Propellers 15" 17" DFDL, Turnigy, RCTimer CW CCW Multirotor Propellers CHEAP ! by Mancini
Page created in 0.897 seconds with 20 queries.
