  • What range should I expect?
anyone flying the weekend? by NigeFPV
[Today at 12:06:15 PM]
Introducing the British FPV Racing League by NigeFPV
[Today at 11:39:58 AM]
Author Topic: What range should I expect?  (Read 2118 times)
Offline Vass
    • My photography
« on: August 17, 2013, 07:46:48 PM »
Hi folks
I intend to do a test on the ground to find out the answer, but would be interested to hear what people think the range should be with my set up for Radio and FPV, then I can compare with actual results to see if somethings not right.
Radio 2.4ghz
Dx6i transmitter set to USA power with 5dB Antenna modification
Spektrum AR6200 trin receiver set vertical and horizontal on model
FPV  5.8ghz
Fatshark 600mw Tx with 3 petal Cloverleaf pointing down from underneath model
Airwave basic 4 Ch Rx with 4 petal Cloverleaf on a Tripod at 6foot height.
Ta for any opinions, its not a test folks, just would like some input
Plus, if you think I could do better somehow, please let me know :-)
Cheers
Vass
www.doubleyolk.co.uk
Re: What range should I expect?
« Reply #1 on: August 17, 2013, 07:56:32 PM »
Your spectrum radio is the weak link here maybe around 500m, if you lose LOS then your quad will drop. (unless you have gps naza or something) You could improve your range with a better receiver like a AR9XXX I personally went onto 35mhz when i started which was good for 5km and then to uhf which I have never been able to go out of range with.
Offline Vass
    • My photography
« Reply #2 on: August 17, 2013, 08:12:31 PM »
current Hex has Audupilot 2.5 with GPS yes
so a AR9000 receiver ( £ 150 ) will help, meaning my Transmitter is reaching that far? :-)
I think I need to read this forum a lot
thanks
Vass
« Last Edit: August 17, 2013, 09:20:49 PM by Vass »
« Reply #3 on: August 17, 2013, 09:27:29 PM »
I would get a compatible or even better jump straight into UHF with rangelink and be able to fly behind buildings close in or 15km away Los!
Offline Vass
    • My photography
« Reply #4 on: August 17, 2013, 09:40:17 PM »
yep, just seen a you Tube clip, EzUHF Tx plugs into Trainer port on my Dx6i
and I just need a Rx
so £ 150 for the EzUHF Tx and whatever Rx is recommended
not too pricey for superb range then :-)
Thanks MrBen, I'm shopping tonight!
« Reply #5 on: August 17, 2013, 09:48:53 PM »
Yeah ezuhf is what I use but rangelink is also good and cheaper, with ezuhf if you use ppm then a 4ch rx will do
« Reply #6 on: August 17, 2013, 10:08:50 PM »
I'm with Ben here, your Spektrum radio isn't renowned for great range.
EZUHF will cost you around £200 plus shipping, thats including a "lite" receiver without diversity.
http://hobbyking.com/hobbyking/store/__25203__ImmersionRC_EzUHF_Transmitter_600mW.html
http://hobbyking.com/hobbyking/store/__25205__ImmersionRC_EzUHF_8_channel_Receiver_Lite_Edition_.html
Rangelink is what I use, and a full set (including receiver) will only cost you £120 plus shipping
I say plus shipping instead of actual cost, because you choose how fast/secure you want it shipped, thereby changing the total cost.
If you're after a cheaper option, I would suggest buying a Turnigy 9XR and a FrSky combo for it, the below links add up to around £70 plus shipping, you're looking at close to 2km in ideal conditions with stock whips with the FrSky equipment
http://hobbyking.com/hobbyking/store/__31544__Turnigy_9XR_Transmitter_Mode_2_No_Module_.html
http://hobbyking.com/hobbyking/store/__31315__Turnigy_9XR_Safety_Protected_11_1v_3s_2200mAh_1_5C_Transmitter_Pack.html
http://hobbyking.com/hobbyking/store/__14348__FrSky_FF_1_2_4Ghz_Combo_Pack_for_Futaba_w_Module_RX.html
if you go down the 9XR route, you'll have a pretty good radio (I rate it, many people on here do too) and will be able to easily upgrade it to UHF at a later date... even experiment with the proper el-cheapo OpenLRS UHF. If you already have APM2.5, then I assume you're already the kind of person who like to fiddle around with software, flashing firmware etc...
http://hobbyking.com/hobbyking/store/__27095__OrangeRx_Open_LRS_433MHz_TX_Module_JR_Turnigy_compatible_.html
http://hobbyking.com/hobbyking/store/__27096__OrangeRx_Open_LRS_433MHz_9Ch_Receiver.html
Offline Vass
    • My photography
« Reply #7 on: August 17, 2013, 10:20:32 PM »
So, if I'm understanding this correctly,
If I go the Rangelink option, I need a Rangelink system which includes a Tx that piggybacks onto a Radio Tx and a Rangelink receiver
The Suggestion would be to use a 9XR for the Radio transmitter and not my Dx6i ?
If thats right?, I'm happy with that :-)
« Last Edit: August 17, 2013, 10:44:16 PM by Vass »
« Reply #8 on: August 18, 2013, 04:13:25 PM »
the rangelink system could plug into your dx6i, but yes I'd recommend buying a 9XR to install the rangelink system into
Offline Vass
    • My photography
« Reply #9 on: August 18, 2013, 06:28:33 PM »
I cannot find "rangelink" anywhere online
Who's the dealer / supplier please, its the only link not given in the thread
Thanks
« Reply #10 on: August 18, 2013, 06:43:14 PM »
oops, sorry.
thought I had already given the link... here you go
http://www.rangepiloting.com/rangelink-set-p-177.html?zenid=g19rkjhothftp38u6iflk4h9r3
Offline Vass
    • My photography
« Reply #11 on: August 22, 2013, 07:24:09 AM »
Ok thanks for the input folks,
Now the FPV
Mega distance is not important, Mr Ben's recent videos is all the range I need, but I'd like to go under a bridge or behind a wall without fear of losing vision
Any suggestion, its payday friday! :-)
Offline chrisallen649
« Reply #12 on: August 22, 2013, 09:35:58 AM »
EzUHF has my vote, personally tested upto 18 km with my z2. On my multi i have hovered a few feet off the floor 2.7km away. had mine 2+ years now never had a problem with it, even when multipule people are flying on ezuhf as well as other uhf systems being used at the same time.
Offline Vass
    • My photography
« Reply #13 on: August 22, 2013, 02:23:53 PM »
for FPV or are you ansering the earlier thread?
sorry maybe I should have started another thread ?
« Reply #14 on: August 22, 2013, 07:20:02 PM »
the lower the frequency the better the penetration but also the larger the antenna (1.2ghz skews are about 5" across) i use 1.2, whips perform well for me also and arent massive the like cp antennas, 2.4 would be ok too, either will work well with uhf (no clashes)
  • Dot Guests: 32
Page created in 1.007 seconds with 22 queries.
