  • Zephyr 2
[April 21, 2015, 05:06:26 PM]
MrBens Happy Wings 'Wipeout' Build Thread by gavnthat
[April 19, 2015, 09:45:15 PM]
Pages: 1 2 [3]
Author Topic: Zephyr 2  (Read 3522 times)
Re: Zephyr 2
« Reply #30 on: January 27, 2012, 05:13:21 PM »
Flight test tried that too, if i remember right their conclusion was that a rudder doesnt have much effect unless it is behind the thrust.
Re: Zephyr 2
« Reply #31 on: January 27, 2012, 05:34:41 PM »
maybe thats why the alulah flies straight then as it has the prop at front and a vertical stab hanging out the back in the prop wash
Offline Quagmire
    • SheldonHoly.co.uk
Re: Zephyr 2
« Reply #32 on: January 27, 2012, 06:23:42 PM »
Also the prop is far forward of the wing. It's pulling it as opposed to pushing it.
Same idea as putting a pencil on a table. Push the pencil from behind and it won't go straight-it'll flop around in circles. Pull it from the front and it'll follow perfectly straight. That is obvious of course, but it would explain why adverse yaw during straight and level flight is almost exclusive to pusher flying wings.
Please, call me Sheldon.
Zephyr 2
« Reply #33 on: January 27, 2012, 09:24:17 PM »
The Alulah also has a fuselage of sorts with its stabilisation fin back past the wing so it has more leverage if you like.
I'm gonna pickup some coroplast and cut some winglet extensions and attach them temporarily. maybe 15-20cm more?
Offline Quagmire
    • SheldonHoly.co.uk
Re: Zephyr 2
« Reply #34 on: January 28, 2012, 12:46:55 PM »
Yeah, make them longer by about a third or so I would say, then try again :)
Zephyr 2
« Reply #35 on: January 28, 2012, 01:12:25 PM »
Bugger.  My zeph likes to tip stall. I was trying to slow it down pointing into the wind when it just stalled into a spin. My recovery attempt ended with it nosing into the ground.
Not much damage. Broke a horn and the nose is a little wrinkled. Cosmetic mostly.
Only worrisome bit is there is a crack in the foam. in an identical place where my slipstream cracked. shouldn't be too bad though I'll probably just use some CA.
Offline Quagmire
    • SheldonHoly.co.uk
Re: Zephyr 2
« Reply #36 on: January 28, 2012, 02:37:37 PM »
Tip stalling zeph?
Sounds fishy....
Offline Quagmire
    • SheldonHoly.co.uk
Re: Zephyr 2
« Reply #37 on: January 28, 2012, 03:36:36 PM »
On my wing build, I think the motor I am planning to use won't quite be powerful enough... So...
I have the option of putting a 600W motor in there (E-Flite Power 25, needs about a 13" prop though!) or 2x smaller, 2217 motors with 9" props each. That would give loads of power and I could set it up with a gyro so the motor speed is adjusted to counteract adverse yaw. Ideas? I would use the E-Sky gyros so it would probably be worthwhile getting a couple extra to try on the pitch and roll axis...
Re: Zephyr 2
« Reply #38 on: February 05, 2012, 07:06:38 PM »
Quote from: Quagmire on January 28, 2012, 02:37:37 PM
Tip stalling zeph?
Sounds fishy....
I suspect the wind had a big part to play in it, I may well have been flying below stall speed and it was too much for one wing or whatever and it just pitched over.
Re: Zephyr 2
« Reply #39 on: April 11, 2012, 08:02:51 PM »
Yo Londonguy I read your zep2 split in half and you are building another  :o :o
What happened?
Pages: 1 2 [3]
  • Zephyr 2
  • user arsui
DJI Store Coupons, 10% OFF, 20% OFF, 30%OFF, by arsui
[Today at 09:22:37 AM]
Page created in 0.981 seconds with 22 queries.
