  • OpenLRS - thUndeadMOD v 2.0 - Booster ready version
Author Topic: OpenLRS - thUndeadMOD v 2.0 - Booster ready version  (Read 877 times)
Offline thundead
  • Fly it like you stole it!
« on: January 09, 2012, 07:39:01 PM »
Hey everyone, thought I'd make another thread just for this version since it is quite different.
First thing's first:
DISCLAIMER
This is still an open source project so may still have bugs but that's why together we can get everything sorted out and have a cheap and reliable system.
this is my second stable version.
Based on 1.10 by Melih
Thanks to Devonian for the 459 mod
A lot of time went into this  firmware so if anyone wants to send me some Pringles and Red Bull to keep me going here is the magic button :))
Pringles & Red Bull Thank You list so far :)
- pk-surfing
- papa_lazerous
- simondale
- Melih (@ Flytron.com)
- CrashingDutchman (@ Flytron.com)
Current Features
- DIVERSITY
- Booster Friendly TX
- Lightweight FW - kept only the basic stuff
- Poor Man's FHSS (thanks to papa_lazerous for suggesting the name :D )
- thUndead's RSSI MOD - fine tuned 3.2 to 0v rssi Vout
- In Flight Fail Safe MOD << YES YOU CAN :P
- 38.4Kbps Baud Rate
Upcoming Stuff
- A bit more brush-up on the code
INSTALLATION
!!! PLEASE DO NOT USE ARDUINO 1.0 SDK! IT will break things! use 0.22 or 0.23 instead !!!
-Load up the firmwares in Arduino and flash them accordingly.
Available FWs:
459Mhz thUndeadMOD v2
http://www.multiupload.com/NC901PXYBY
DOCUMENTATION
Lightweight Firmware
This firmware is designed for long range so non essential things have been taken out. If you need telemetry, use v1.5.
Poor Man's FHSS
Channels are grouped in sets of 3 and you can manually hop between sets by short pressing the TX button. You can add as many sets as you want but always keep a common channel! be sure to change CHNO to your total channel number and always have sets of three !
Booster Friendly FW for TX
If you have Melih's booster you need to make BOOSTER 1 in config.h.  This changes the output power from 1 0 0 mw to 50mw which is the recommended input power for the booster.
Short insight on the booster: all I can say is, minimum power, 124mA current draw, 1.5km ground range through buildings and a hill lol.
DIVERSITY
The Diversity algorithm is very simple: Second receiver acts as a repeater for the incoming signal. Simple and effective :D
Hardware Installation is very simple, just use a 2 wire Servo cable to supply the slave RX with GND and VCC from onw of the master RX's free servo ports or other 5V supply.
Software Installation: Just load the openLRS_RXS firmware onto the slave receiver and you are ready to go.
RSSI on the slave RX is still available either on pin 8 (v2 hw) or pin 9 (v1 hw)
OpenLRS Diversity Small | Large
RSSI: V output: min/max 0-3.2v
CALIBRATION:
uncomment Serial_RSSI in the config.h file (the RX one) and with you TX and RX ON check the outputted value in the Serial Monitor   ( going in the other room might increase the value lol ) and that should be your max RSSI output.
in the config.h change the max value accordingly:
//###### RSSI STUFF ########
#define RSSI_MAX 110 //turn on the RSSI debug and see what values you r getting at close range....
#define RSSI_SMOOTH  60   //increase if the Vout is still jumpy.
RSSI ON v2 BOARDS IS on CH 8 !
If the Vout is still jumpy, increase RSSI_SMOOTH and recheck your RSSI_MAX
In Flight Fail-Safe: nothing to change/calibrate here. Simply press and release the TX button after 2 secs and your F/S values are stored. You should see the red LED on the RX blink  when FS has been saved.
Hope that was an interesting read,
Cheers,
Mihai.
If you like my work feel free to contribuite to my Pringles & Red Bull Fund :)
https://fpv-forum.com/index.php?topic=79.0
My Fleet:
Carbon Tricopter - AP - multiwii
the "Indestructible" tricopter - kkboard
60" ScoutBee wing + RVOSD5
48" EleBee
Retired
Sky Surfer
Stryker F27c
Offline thundead
Re: OpenLRS - thUndeadMOD v 2.0 - Booster ready version
« Reply #1 on: January 09, 2012, 07:43:22 PM »
<<reserved >>
My Fleet:
48" EleBee
Retired
Sky Surfer
Stryker F27c
Page created in 1.213 seconds with 20 queries.
