  • Ritewing Zephyr 2 Build Log by MrBen
What should i buy first by ginop68
[Today at 12:15:21 AM]
What did the postman bring you today? by ginop68
[Today at 12:10:27 AM]
Xiaomi Yi 60fps raw by mark1975
[April 28, 2015, 08:33:25 PM]
[April 28, 2015, 03:29:10 PM]
sunny day fpv by gavnthat
[April 28, 2015, 12:20:58 PM]
windy day Teksumo fpv by bigMouse
[April 28, 2015, 09:16:07 AM]
OSD vs DIJ NAZA lite M by mikb
[April 27, 2015, 10:34:12 PM]
Spanky5 Race Practise by MrBen
[April 26, 2015, 09:07:03 AM]
[April 26, 2015, 06:46:13 AM]
Hobbyking Durafly Me-163 Komet 950mm FPV Bungee and crash by bigMouse
[April 24, 2015, 07:17:40 PM]
[April 24, 2015, 08:07:18 AM]
Pages: 1 [2] 3 4 ... 7
Author Topic: Ritewing Zephyr 2 Build Log by MrBen  (Read 12581 times)
Re: Ritewing Zephyr 2 Build Log by MrBen
« Reply #15 on: April 24, 2012, 09:50:27 AM »
Although the manufacturers recommend placing gyro stabilisations systems at or near to the CG, there's no difference in the performance of the stabilisation. There's a guy on youtube [experimentalairlines] who did a video demonstration to show the "science" of it. theoretically you could put the AP far out on the wing, as long as it's flat and pointing in the right direction. :)
« Reply #16 on: April 24, 2012, 09:40:10 PM »
just unwrapped my laminate, 2850 x 635 for £30  :o :o
« Last Edit: May 11, 2012, 03:48:50 PM by MrBen »
« Reply #17 on: April 24, 2012, 09:41:30 PM »
please tell me is that expensive for laminate never actually ordered any before.
« Reply #18 on: April 24, 2012, 09:44:43 PM »
well I would suggest anyone checks out before they buy it! isnt PK selling some? I bet he is loads cheaper!
Offline Quagmire
    • SheldonHoly.co.uk
« Reply #19 on: April 24, 2012, 10:26:47 PM »
If you get the waggling problem, maybe consider adding wing fences. I think it might do a great deal of good to straighten out the airflow over the wing as there are no vertical surfaces apart from at the tips.
Please, call me Sheldon.
6lennn
« Reply #20 on: April 24, 2012, 11:06:22 PM »
Quote from: MrBen on April 24, 2012, 09:40:10 PM
just unwrapped my laminate, 2850 x 635 for 30euro  :o :o
dunno what those numbers mean, but I had more than enough to cover mine
got mine from readymaderc
where did you get yours from?
« Reply #21 on: April 24, 2012, 11:15:15 PM »
i got mine from http://desirerc.co.uk/
those figures are in mm so 9ft x 2ft roughly all in one long piece, is that how yours came? mine is all same thickness too, with the zep1 I got some thicker stuff for the belly.
6lennn
« Reply #22 on: April 24, 2012, 11:38:27 PM »
I had leftovers, plenty, and i only got the one thickness too, feels quite heavy
« Reply #23 on: May 02, 2012, 06:41:43 PM »
Ok so now all the spars are in, the spar slots have been filled sanded, filled sanded, filled sanded and the whole wing has had a good sand too, raised logos gone too, I want the laminate to be flat!
I have melted a whole through from the servo through to the rear compartment which is where RVOSD will be positioned. RVOSD ordered waiting on delivery!
I have cut in the hole for the VTX on the top of the wing but in the interest of keeping the look as clean as possible I am thinking about running the wires on the underside of the wing in a channel, then some white tape over them before its lam'd. I have already laminated the red elevons.
Really waiting for the OSD before I can progress too much, I need to order some 1m servo wire from giantcod to run to vtx from back compartment and also PPM/RSSI cables from UHF on opposite wing to OSD.
« Last Edit: May 02, 2012, 07:01:01 PM by MrBen »
6lennn
« Reply #24 on: May 02, 2012, 06:58:50 PM »
nice, I'll be interested to see how you get on with laminating the underside, there is a hollow bit nose to tail both side of the main belly on the underside
I simply couldnt getthe lam to stick there, seems like a bit of a design "feature" to me
imo this is a right pain in the backside
gl
« Reply #25 on: May 02, 2012, 07:04:06 PM »
yeah as on pic 5 above glenn?, did you spray your wing with adhesive before you laminated it?
6lennn
« Reply #26 on: May 02, 2012, 07:07:16 PM »
yes mate, used 3m90
but the laminate is very tough (read thick) so try as I might I coulnt get it to cling into the groove
itjust kept shrinking away
« Reply #27 on: May 02, 2012, 07:15:53 PM »
I'll bear in mind to start from that area then and work away, see if I can nail it :)
« Reply #28 on: May 03, 2012, 05:37:25 AM »
Well this is the recommended spray glue so just ordered a tin, also some servo wires and ubec on order from giant cod. I'll sink the necessary wires in then lam it.
« Reply #29 on: May 03, 2012, 11:45:33 AM »
Quote from: MrBen on May 03, 2012, 05:37:25 AM
Where did you get the spray from mate?
Also did you make the battery tray yourself or buy it? It deffo needs strengthening, I made mine outa ply.
  • user ginop68
Naza M Complete With Gps by Martink1974
[April 26, 2015, 09:13:33 PM]
[April 24, 2015, 09:18:59 PM]
[April 23, 2015, 07:17:14 PM]
Page created in 0.777 seconds with 19 queries.
