  • naughty quad
Springbound Vid by mark1975
[Today at 08:35:50 PM]
marks emax 250 pro by mark1975
[Today at 08:04:06 PM]
[Today at 01:41:43 PM]
This looks interesting - Ritewing Drak by Martink1974
[March 13, 2015, 11:22:05 PM]
Another UAV quad by bigMouse
[March 13, 2015, 09:10:44 PM]
Storm 32 Brushless Gimbal Controller by MrBen
[March 13, 2015, 06:40:56 PM]
FPV Spanky Magic Smoke Edition by JAB1a
[March 13, 2015, 11:06:18 AM]
Had enough of Naza, going APM by Tecnic
[March 12, 2015, 10:00:10 AM]
FPV Related 3D Prints by Mancini
[March 11, 2015, 04:26:12 PM]
Introducing the "Wipeout - by Happy Flyers" by MatthiasC
[March 09, 2015, 12:41:58 PM]
More mini fun and more crashing by bigMouse
[March 09, 2015, 08:39:30 AM]
Spanky6 2k Res by MrBen
[March 08, 2015, 08:08:22 PM]
anyone flying the weekend? by mark1975
[March 08, 2015, 12:57:37 PM]
Cobs mini Tricopter on 2s with 5x3 props by MrBen
[March 08, 2015, 12:28:37 PM]
naughty quad by xxpitt
[March 07, 2015, 04:22:55 PM]
FMX250 LED Mini Quadcopter ARF RTF by Tecnic
Ultra Wide 1.8mm FPV CCTV Camera Lens 12mm MTV Thread by Tecnic
LHCP Skew Planar/Clover Sets by Tecnic
New 5.8Ghz Diversity Receiver by Tecnic
New Mini 600mw 5.8Ghz TX 12.8 grams and push button by Tecnic
[March 11, 2015, 11:30:44 AM]
Author Topic: naughty quad  (Read 65 times)
naughty quad
« on: March 07, 2015, 03:13:30 PM »
Ok,
 so had so much go wrong lately. Killed esc after esc trying to run oneshot. so ben kindly leant me a set of emax 12a, but obviously he wants them back in same condition he gave them to me. So I've not flashed any firmware or chopped any wires. So the whole thing looks a bit messy. also I had to solder some esc plugs on as I couldn't get header pins onto the board as all the pin holes are blocked with solder from when I hard wired it.
Also on my old board there was some kind of internal short somewhere as I was getting continuity between every neg and pos pin and pad on the board. Unfortunately I had already plugged esc's bec into power board and it got rather warm fairly fast  :-[ sorry ben. Now I've wired up the back up board that bec that got rather warm is powering naze fine but it is warming up a little. Should I use a different esc to power board just to be safe? Or is it normal foe esc that powers naze to warm up. Been that long since I've flown I can't even remember?
Re: naughty quad
« Reply #1 on: March 07, 2015, 03:54:58 PM »
The naze is lighting up so there can't be a direct short on that particular board.
Yes if a bec is used, its normal for that ESC to get a bit warmer than the others!
Yes its been a long time! Give us a shout if you need some flying tuition! lol
What were the escs you had problems with! Was it your actions or the ESC didn't like clean flight?
Re: naughty quad
« Reply #2 on: March 07, 2015, 04:22:55 PM »
this is a different naze that does work, my other one would only power off usb, wouldn't accept power anywhere else and multimeter  showed there was continuity between pos and neg at ever pin on board, the escs i killed were 12a blue series 2 of the 4, and the f20a hobbyking esc, all just intermittent, probably could of fixed it by reflashing with simonk, it was blheli and oneshot that the esc's didn't like, someone else on other forum was having same issues with same escs as me. he finally got his in the air but one failed on him in flight, for what its worth he said they were great while they lasted. these emax ben has lent to me are blheli but not not going to update firmware and enable oneshot
  • naughty quad
  • Dot Guests: 35
Wanted : LaserBGC 1.3 module for fatshark goggs by MrBen
[March 07, 2015, 07:05:53 PM]
Best legal long range setup by BIRDS-EYE-VIEW.NL
[February 27, 2015, 03:57:22 PM]
Page created in 1.228 seconds with 21 queries.
