  • Camera gimbals »
  • Storm 32 Brushless Gimbal Controller
Springbound Vid by Martink1974
[Today at 09:31:19 PM]
marks emax 250 pro by mark1975
[Today at 08:04:06 PM]
[Today at 01:41:43 PM]
This looks interesting - Ritewing Drak by Martink1974
[March 13, 2015, 11:22:05 PM]
Another UAV quad by bigMouse
[March 13, 2015, 09:10:44 PM]
Storm 32 Brushless Gimbal Controller by MrBen
[March 13, 2015, 06:40:56 PM]
FPV Spanky Magic Smoke Edition by JAB1a
[March 13, 2015, 11:06:18 AM]
Had enough of Naza, going APM by Tecnic
[March 12, 2015, 10:00:10 AM]
FPV Related 3D Prints by Mancini
[March 11, 2015, 04:26:12 PM]
Introducing the "Wipeout - by Happy Flyers" by MatthiasC
[March 09, 2015, 12:41:58 PM]
More mini fun and more crashing by bigMouse
[March 09, 2015, 08:39:30 AM]
Spanky6 2k Res by MrBen
[March 08, 2015, 08:08:22 PM]
anyone flying the weekend? by mark1975
[March 08, 2015, 12:57:37 PM]
Cobs mini Tricopter on 2s with 5x3 props by MrBen
[March 08, 2015, 12:28:37 PM]
naughty quad by xxpitt
[March 07, 2015, 04:22:55 PM]
FMX250 LED Mini Quadcopter ARF RTF by Tecnic
Ultra Wide 1.8mm FPV CCTV Camera Lens 12mm MTV Thread by Tecnic
LHCP Skew Planar/Clover Sets by Tecnic
New 5.8Ghz Diversity Receiver by Tecnic
New Mini 600mw 5.8Ghz TX 12.8 grams and push button by Tecnic
[March 11, 2015, 11:30:44 AM]
Pages: 1 [2]
Author Topic: Storm 32 Brushless Gimbal Controller  (Read 530 times)
Re: Storm 32 Brushless Gimbal Controller
« Reply #15 on: March 03, 2015, 06:56:22 PM »
Just for the hell of it I did a complete erase! Here is the settings I used to flash the board!
Couple of points:
I connected the storm board to the laptop via usb, this was to supply the board with 5v.
Also connected the USB/TTL to a laptop usb socket
Make sure you select the right comm in the right hand drop down box. If there is two or more their then unplug the USB programmer, re plug it in the laptop and see what comm is added, use that number!
For the bottom left comm port I used the other one that was showing in the last drop down list!(not the same one)
Don't forget to press the buttons prior to flashing! (and in the right order), after pressing the buttons the board should look dead, after flashing it reboots and lights up again.
Hope this is all clear
« Last Edit: March 03, 2015, 07:01:23 PM by bigMouse »
« Reply #16 on: March 03, 2015, 07:54:56 PM »
All sorted, Im just printing a calibration cube for the IMU's
« Reply #17 on: March 03, 2015, 09:14:42 PM »
Looks good!
I made something like that once for an IMU on another gimbal, but had to make it out of wood! Much easier now with the printer!
« Reply #18 on: March 05, 2015, 09:19:41 PM »
First flight, some horizon drift but I havent done a proper level 6 axis calibration yet.
QAV400 with DYS 3 Axis / Storm 32 Bit Controller
« Reply #19 on: March 05, 2015, 09:41:44 PM »
Looked impressive!
Noticed the horizontal drift, hopefully should be able to eliminate that with some tweaking!
« Reply #20 on: March 06, 2015, 02:24:10 AM »
yeah Im hoping it just needs a proper calibration to get rid of that
same video again but in 1080p 60 fps
QAV400 with DYS 3 Axis / Storm 32 Bit Controller 1080p
« Reply #21 on: March 11, 2015, 06:34:17 PM »
I designed this calibration cube for the main board (imu) and I'm getting a score in the 90's (less than 100 is good, 150 is acceptable over 200 in unacceptable)
Struggling to get a score lower than 250 with the calibration cube I found online for the small camera IMU though and I have tried 2 different IMU's (I got a spare) so Im just printing out my own design and will post it here if it works ok
« Reply #22 on: March 11, 2015, 09:09:14 PM »
Just got a 103 score on the small IMU with this calbration cube, I put a small dab of uhu por on the IMU to hold it in place during calibration
« Reply #23 on: March 11, 2015, 09:40:36 PM »
I don't understand why the different calibration cubes are producing different results!
Is it more to it than just an accurate square box?
« Reply #24 on: March 12, 2015, 07:07:08 AM »
Well the one I downloaded was originally too small to slide the IM inside so I reprinted it 3% larger but now the slot was wide enough but too tall and too short and causing poor scores. It also has a small surface area compared to mine I think the larger cubes are more accurate.
« Reply #25 on: March 12, 2015, 08:15:39 AM »
Yea that makes sense!
« Reply #26 on: March 13, 2015, 12:05:08 PM »
http://youtu.be/OuOI3fbvz-4
Even after good calibration scores on the imu's I still have some horizon drift to eliminate.
« Reply #27 on: March 13, 2015, 06:16:02 PM »
Don't know what to suggest!
At least it looks about the same in both directions!
« Reply #28 on: March 13, 2015, 06:40:56 PM »
gonna re-calibrate and test again
Pages: 1 [2]
  • Camera gimbals »
Wanted : LaserBGC 1.3 module for fatshark goggs by MrBen
[March 07, 2015, 07:05:53 PM]
Best legal long range setup by BIRDS-EYE-VIEW.NL
[February 27, 2015, 03:57:22 PM]
Page created in 1.456 seconds with 20 queries.
