  • First flight with my Tarot T810
Spanky 5 Dropped From the Sky by MrBen
[Today at 06:18:43 AM]
spring is in the air by mark1975
[March 22, 2015, 09:11:33 PM]
Pixhawk on quadcopter by Tecnic
[March 22, 2015, 02:41:28 PM]
Scottish Borders Counties Rally Aerial Fotage HD by Mancini
[March 22, 2015, 01:58:11 PM]
[March 21, 2015, 01:00:48 PM]
Gopro Live out through switcher video problem by xxpitt
[March 21, 2015, 11:58:13 AM]
Mark having a fly with my 270 miniquad by Brodjackella
[March 20, 2015, 12:02:02 PM]
naze ppm mapping by Brodjackella
[March 20, 2015, 11:57:47 AM]
Author Topic: First flight with my Tarot T810  (Read 131 times)
Offline mackar
    • Tarot T810 Build
« on: January 28, 2015, 09:41:29 AM »
I've been building a Tarot T810 for a while www.maciej.se/T810.html
I was finally able to do a maiden flight this weekend
Tarot T810 wit Pixhawk FC - Maiden flight
Still some configuration left before I can start filming with it. Really satisfied with the performance of Pixhawk FC, the hexa was really stable in GPS Hold mode
My Tarot T810 build log
http://www.maciej.se/T810.html
Re: First flight with my Tarot T810
« Reply #1 on: January 28, 2015, 07:36:38 PM »
Looked at your build thread! Very interesting!
Couple of thoughts!
Those antenna on the 3DR radios, I would change (at least the airborne one). A decent strike and it will rip the SMA connector off the pcb.
My spare 3DR radios are very old (MK1) I had to make a lead up for connection to my pixHawk! No commercial ones available!
Wondered why you decided on using a six way switch! Do you think it will be easy to know what flight mode you are switched to?
I have Droid planner on Android but not used it in anger yet, much prefer the larger screen of a Laptop, but then, my eyesight is probably not as good as yours!
You say the current sensor on the Power module has failed before! Is this even when drawing much less than the rated 90 amps?
Yes those 3d printed frames are really good...
Offline mackar
    • Tarot T810 Build
« Reply #2 on: January 28, 2015, 09:16:45 PM »
Quote from: bigMouse on January 28, 2015, 07:36:38 PM
Thanks for you comments :-)
I thought that if I crash so badly that the antenna rips off then the radio is my smallest problem ;-)
Yes, for me it will be quite easy, if I start in the middle I'm in Stabilize, one click to the right I'm in Alt Hold, two steps to the right I'm in Loiter, one step to the left I'm in Position Hold, two steps to the left I'm in Circle mode and three steps to the left I'm in Landing mode. The radio also has a spoken message telling me in which position I'm in.
Don't have any info about how much power they have been drawing when the power modules failed. I don't feel that I need to have current monitoring so I'm bypassing it instead of risking a failure.
Page created in 0.648 seconds with 22 queries.
