  • Skywalker build
Damped Light ESC and Programming by Smit80
[Today at 02:27:00 PM]
[Today at 08:39:55 AM]
[May 04, 2015, 07:42:23 PM]
Chasing mr.ben by bigMouse
[May 04, 2015, 04:40:29 PM]
[May 04, 2015, 04:39:10 PM]
Setting up a mix on taranis **HELP** by MrBen
[May 03, 2015, 09:12:39 PM]
Help :) :-) by bigMouse
[May 03, 2015, 10:03:21 AM]
Micro Minim OSD (MWOSD for Naze) by bigMouse
[May 03, 2015, 09:57:02 AM]
x5 maiden by xxpitt
[May 03, 2015, 09:48:59 AM]
[May 02, 2015, 07:43:10 PM]
[May 02, 2015, 06:19:07 PM]
Getting Back into it - FPV Spanky Callidus80 - Cobra 1960Kv by xxpitt
[May 02, 2015, 03:14:40 PM]
New 250 FPV Racer by JUST CRASH
Limited Offer: FPVModel MC4012 340KV Motors Sold At $23.49 by fpvmodel
[April 29, 2015, 08:46:53 AM]
Author Topic: Skywalker build  (Read 2947 times)
Offline Marklincs
Skywalker build
« on: March 16, 2012, 12:12:03 PM »
I've been busying away with my skywalker build 1900mm
Now I've done some Mods and who hasn't!
My main ones so far are the Ailerons adding in proper wing hinges 2 on each Aileron
I cut slots in the foam and super glued them in then added some fibre tape on top as a just in case.  Then the main Aileron control hinge is no longer push into the wing and hope it doesn't pull out. A layer of fibre tape then 2 screws through the horn to a plastic stop the other side and the same for the rudder and elevator.
Main hatch for access to internals cut on both sides.
Magnets now hold the canopy in place.
The wing is now one piece glued together, no way could you leave it a 2 piece wing, you couldn't trust it.
Skywalker/Quad/ Fatsharks 5.8ghz
Re: Skywalker build
« Reply #1 on: March 16, 2012, 12:22:52 PM »
How does the wing slot in? Any alterations to the fuselage required now it's in one piece?
Offline Marklincs
Re: Skywalker build
« Reply #2 on: March 16, 2012, 12:39:57 PM »
Wing is not any different really just slots into place.
But the important bit is the wing should be a lot stronger as a one piece
Offline Marklincs
Re: Skywalker build
« Reply #3 on: March 22, 2012, 03:29:53 PM »
Test flown today....
can turn left okay but not right...
flys okay on rudder though....
Re: Skywalker build
« Reply #4 on: March 22, 2012, 05:20:46 PM »
have you got enough movement on ailerons then?
Offline Marklincs
Re: Skywalker build
« Reply #5 on: March 22, 2012, 05:47:27 PM »
Re-done all my links now awaiting test flight number 2 :)
now 2mm Rod and proper clevasis :)
Re: Skywalker build
« Reply #6 on: March 22, 2012, 10:51:17 PM »
could have much more throw ,just fit "rod holder" sorry don't know name for that  ;D closer to wing edge..I mean closer to aileron edge "where wing connect with aileron" ...damn will draw it for you.. ;D
Re: Skywalker build
« Reply #7 on: March 22, 2012, 11:02:54 PM »
Yup that control horn is an awfully long way back. Move it toward the hinge .
Sent from my GT-I9000 using Tapatalk
Online papa_lazerous
Skywalker build
« Reply #8 on: March 22, 2012, 11:03:42 PM »
A couple of points to bring up is that the skywalker is a big bird add the longer wings like you have and I'd expect to it be a little docile getting a turn going. I'd be inclined to set up the ailerons with a differential throw as that will make the biggest difference. I have my ailerons on one channel so had to do it mechanically by having the servo arms set biased when the servos where centred but works a treat. I only did that so I'd get good aileron authority so the RTH would perform well. But to be honest I fly it like you should with any big glider and that's coordinated turns with aileron and rudder and usually a touch of elevator too.
Sent from my iPhone using Tapatalk
Skywalker build
« Reply #9 on: March 22, 2012, 11:05:13 PM »
Oh and the horn should be wayyy forward like stated above,
Offline Marklincs
Re: Skywalker build
« Reply #10 on: March 23, 2012, 06:24:50 PM »
Well update time
mixed in rudder now flys like a dream...
Re: Skywalker build
« Reply #11 on: March 23, 2012, 07:07:39 PM »
cool, now she flies its time to stick the FPV gear on!!
Offline Marklincs
Re: Skywalker build
« Reply #12 on: March 23, 2012, 07:23:48 PM »
Quote from: MrBen on March 23, 2012, 07:07:39 PM
just going do some indoor tests as its new wiring...
Offline Marklincs
Re: Skywalker build
« Reply #13 on: March 24, 2012, 06:05:08 PM »
Well 2 more test flights without FPV gear and man o man the skywalker is insane at 1 meter or less off the deck
 ;D ;D
I was just having silly fun and when you take it high the glide on it is unreal... This will thermal for sure on a nice day...
I've had a Glider at 1250 meters and I can see this reaching it if the video signal holds out....
other wise base antenna will require an upgrade...
I might program in a stall option on a switch so if I loose signal at height to force it down as a precaution....
Offline Quagmire
    • SheldonHoly.co.uk
Re: Skywalker build
« Reply #14 on: April 02, 2012, 01:02:47 PM »
Yeah, the holes on the control horn must always be over the hinge line. You will experience far more positive control with the horns in the correct position.
Please, call me Sheldon.
  • Skywalker build
  • Dot Users: 8
  • user Smit80
  • user JUST CRASH
Page created in 1.055 seconds with 21 queries.
