  • Freak accident
Spanky 5 Dropped From the Sky by Brodjackella
[Today at 12:26:51 AM]
spring is in the air by mark1975
[March 22, 2015, 09:11:33 PM]
Pixhawk on quadcopter by Tecnic
[March 22, 2015, 02:41:28 PM]
Scottish Borders Counties Rally Aerial Fotage HD by Mancini
[March 22, 2015, 01:58:11 PM]
[March 21, 2015, 01:00:48 PM]
Gopro Live out through switcher video problem by xxpitt
[March 21, 2015, 11:58:13 AM]
Mark having a fly with my 270 miniquad by Brodjackella
[March 20, 2015, 12:02:02 PM]
naze ppm mapping by Brodjackella
[March 20, 2015, 11:57:47 AM]
Author Topic: Freak accident  (Read 540 times)
Freak accident
« on: November 26, 2014, 03:28:51 PM »
Flying a couple of the minis today and on one of the landings quite softly in grass it caught fire!, was able to run to it and pull the battery plug. What happened was the 2.4 Rx antenna (the metal bit on the end) was pressed into the bottom plate hole by the grass, just enough to short out the pdb, which is what caught fire!. Will show some more pics once I get around to taking the bottom plate off, no idea of the extent of the damage yet!
Re: Freak accident
« Reply #1 on: November 26, 2014, 05:56:54 PM »
Bare live pads bM
Not good enough young man
I cover mine with solder just to make sure :)
Re: Freak accident
« Reply #2 on: November 26, 2014, 05:59:01 PM »
looks like a lot of current has caused that , is the frame carbon ?
Re: Freak accident
« Reply #3 on: November 26, 2014, 06:50:35 PM »
Quote from: Martink1974 on November 26, 2014, 05:59:01 PM
looks like carbon in the pic but I'd it's the emax I have its not actual carbon. But if it is carbon I would use a loom over a pdb. Or at least voter in hot glue once your finished soldering
Re: Freak accident
« Reply #4 on: November 26, 2014, 07:41:40 PM »
yea carbon frame! Battery was hot, the resin in the cf plate around the pdb burned leaving the carbon weave behind, Battery lead and both front esc supply wires burnt off, Naze board singed, Cam board showing signs of heat damage, nothing tested yet, here are some more pics.
Re: Freak accident
« Reply #5 on: November 26, 2014, 07:50:12 PM »
Quote from: Tecnic on November 26, 2014, 05:56:54 PM
Bare live pads bM
Probably a good idea to cover the pdb with some thin insulated sheet! Must admit, all my pdb's are exposed
Re: Freak accident
« Reply #6 on: November 27, 2014, 11:26:54 AM »
Here are a few more pics, surprising how much was affected!
This is the board cam pcb
Re: Freak accident
« Reply #7 on: November 27, 2014, 11:28:47 AM »
And here the naze top and bottom.
Next will wash everything in IPA see if anything works...
Re: Freak accident
« Reply #8 on: November 28, 2014, 09:07:46 PM »
This is the rebuild, a cover plate made from 0.5mm paxolin sheet
Re: Freak accident
« Reply #9 on: November 28, 2014, 09:16:40 PM »
fingers crossed on the naze
Re: Freak accident
« Reply #10 on: November 30, 2014, 09:38:44 AM »
yay, finished...
Re: Freak accident
« Reply #11 on: November 30, 2014, 06:07:51 PM »
Everything working then? Nothing damaged?
Re: Freak accident
« Reply #12 on: November 30, 2014, 06:27:29 PM »
Fat boy 4s lipos. I'm running this to and my quad is shifting some. It weighs over 600g too
« Last Edit: December 01, 2014, 12:05:16 AM by xxpitt »
Re: Freak accident
« Reply #13 on: November 30, 2014, 07:21:12 PM »
All tested and working except the board cam,  even the battery survive which was quite a surprise as it was hot when I disconnected...
Dave, as you see mine in the last picture, ready to fly (minus vtx and Mobious) is 525 grams
Offline BIRDS-EYE-VIEW.NL
    • BIRDS-EYE-VIEW.NL
Re: Freak accident
« Reply #14 on: February 17, 2015, 07:57:06 AM »
Instead of adding plates over the electronic components I would suggest to coat your components with a PU coating. This makes them moisture/ weather resistant to and prevent shorts and you save weight. And for next time always isolate your antennas with heat-shrink. Of course not the standard heat shrink because the carbon and metal additives block the signal. But there is special heat shrink for High frequency applications around. (call farnell or an other supplier they have it on stock)
  • Freak accident
  • Dot Guests: 44
Page created in 1.481 seconds with 24 queries.
