  • Other »
  • CNC Routing & 3D Printing »
  • 3d Printer?
Transmitting Module (first Question!) by carlr
[Today at 10:21:37 AM]
FPV Racing Fun in Somerset 60fps by JAB1a
[Today at 09:40:10 AM]
[May 13, 2015, 07:44:39 PM]
[May 13, 2015, 06:49:11 PM]
bargain frsky rx by xxpitt
[May 13, 2015, 06:20:21 PM]
Gimbal for a Gaui 500x ... by bigMouse
[May 13, 2015, 08:51:19 AM]
All emax 250 owners cool site if you own a 3d printer by bigMouse
[May 13, 2015, 08:48:57 AM]
BFPVRL meet at Rotors fly in Cheshire by xxpitt
[May 11, 2015, 11:34:26 PM]
not so hot lap by xxpitt
[May 11, 2015, 10:41:03 AM]
Spanky6 Bank Holiday Monday Flights by gavnthat
[May 11, 2015, 09:54:59 AM]
[May 11, 2015, 06:49:15 AM]
[May 11, 2015, 06:25:48 AM]
BFPVRL @ ROTORS FLY IN by the famous xxpitt by MrBen
[May 11, 2015, 06:01:17 AM]
NEW FLIGHT CONTROLLER heads up by bigMouse
DJI Phantom 3 Available in Stock by fpvmodel
[Today at 08:51:16 AM]
Pages: 1 ... 3 4 [5] 6 7 ... 9
Author Topic: 3d Printer?  (Read 3603 times)
Re: 3d Printer?
« Reply #60 on: December 07, 2014, 12:47:49 PM »
just tested mobius lens protector and it shows up in the video mate  :-[ needs to be shorter or wider
Re: 3d Printer?
« Reply #61 on: December 07, 2014, 12:57:55 PM »
maybe I need to print one out for dave ;) my mobius never comes off
thats a impressive resolution on the Ultimator2!
@Dave, you would think the designer would have check this right! Well my mobius is playing up I think the battery has died so not been able to test it this morning although I have tried! I think I have a spare battery from my first mobius somewhere.
Re: 3d Printer?
« Reply #62 on: December 07, 2014, 01:06:34 PM »
i unscrewed the lens a bit trying to get it off now my lens is loose and cant find right size alan key to fit it  :'(
Re: 3d Printer?
« Reply #63 on: December 07, 2014, 01:09:51 PM »
you get one with it, just managed to check mine and its in shot a little bit, will sand 1-2mm off back, that should do it!
Re: 3d Printer?
« Reply #64 on: December 07, 2014, 01:22:33 PM »
yeah found the one that came with it sorted now
Re: 3d Printer?
« Reply #65 on: December 07, 2014, 01:24:45 PM »
by time you've sanded 2mm off there might not be that much protection there. handy just to  help find it though i guess, i might do it myself, but only got tiny files i got to sand the holes out on that frame you sold me will take ages
Re: 3d Printer?
« Reply #66 on: December 07, 2014, 01:32:41 PM »
here are a few interesting intros into the use of pla v abs! (have only included the links)
Reading between the lines it appears that industry mainly uses abs because it is more stable (all round) than pla, hobbyists use pla because it gives a sharper print and it smalls nicer while printing.
https://www.youtube.com/watch?v=FLItphmriCw
https://www.youtube.com/watch?v=XaQA_EccZkk
https://www.youtube.com/watch?v=4BYfsksaNKY
https://www.youtube.com/watch?v=wF-w3eT0CdY
Re: 3d Printer?
« Reply #67 on: December 09, 2014, 04:02:31 PM »
I had loads of issues with my k8200 with the printed object lifting off the heated base until I started using a wood glue / water mix to make the base 'grabby'. Just incase any one else has that issue.
Sent from my iPad using Tapatalk
Re: 3d Printer?
« Reply #68 on: December 09, 2014, 07:02:25 PM »
Why don't you print us some tilted motor mounts benjamin
Re: 3d Printer?
« Reply #69 on: December 09, 2014, 07:14:01 PM »
for sure but I just changed over to PLA and incase of heat you need ABS ones to let me get some PLA prints under my belt first before I change back
Re: 3d Printer?
« Reply #70 on: December 09, 2014, 07:15:11 PM »
doing a group buy on NEMA17 stepper motor dampers
minimum order quantity is 10, already upto 9 quantity, does anyone here want and dampers too?
Its going to be about £10ish quid plus postage for 3
http://astrosyn.com/product.php/74/my17rmdamp
« Last Edit: December 09, 2014, 07:17:52 PM by MrBen »
Re: 3d Printer?
« Reply #71 on: December 10, 2014, 09:05:20 PM »
My rostock v2 in action
Rostock Max v2 3d Printer Demo
Re: 3d Printer?
« Reply #72 on: December 10, 2014, 10:30:03 PM »
My first print, it is tiny, 15mm high, 1.5mm walls. Drew it up in cad, saved as stl, opened it in cura and saved the files, never thought the cross tube would ever print but they came out better than expected, next time will some build in some supporting structures...
photos really bad, poor light, and flash.
Re: 3d Printer?
« Reply #73 on: December 12, 2014, 06:05:28 PM »
is that ABS or PLA? you might get better results with PLA and slower nozzle with good fan cooling on the part
Re: 3d Printer?
« Reply #74 on: December 12, 2014, 06:21:31 PM »
PLA, Printed the part again today and was quite a bit better, only slight drooping on the lower side of the cross arms!
Had some success (and a failure today) vid to follow! Youtube fails to upload, screen just looks at me, Obviously I'm not paying google enough money!
  • Other »
  • 3d Printer?
Page created in 0.581 seconds with 21 queries.
