  • Other »
  • CNC Routing & 3D Printing »
  • 3d Printer?
Transmitting Module (first Question!) by bigMouse
[May 13, 2015, 08:09:52 PM]
[May 13, 2015, 07:44:39 PM]
[May 13, 2015, 06:49:11 PM]
bargain frsky rx by xxpitt
[May 13, 2015, 06:20:21 PM]
FPV Racing Fun in Somerset 60fps by xxpitt
[May 13, 2015, 06:18:34 PM]
Gimbal for a Gaui 500x ... by bigMouse
[May 13, 2015, 08:51:19 AM]
All emax 250 owners cool site if you own a 3d printer by bigMouse
[May 13, 2015, 08:48:57 AM]
BFPVRL meet at Rotors fly in Cheshire by xxpitt
[May 11, 2015, 11:34:26 PM]
not so hot lap by xxpitt
[May 11, 2015, 10:41:03 AM]
Spanky6 Bank Holiday Monday Flights by gavnthat
[May 11, 2015, 09:54:59 AM]
[May 11, 2015, 06:49:15 AM]
[May 11, 2015, 06:25:48 AM]
BFPVRL @ ROTORS FLY IN by the famous xxpitt by MrBen
[May 11, 2015, 06:01:17 AM]
NEW FLIGHT CONTROLLER heads up by bigMouse
Pages: 1 ... 6 7 [8] 9
Author Topic: 3d Printer?  (Read 3599 times)
Re: 3d Printer?
« Reply #105 on: December 14, 2014, 10:26:54 PM »
why print when you can doodle?
http://www.maplin.co.uk/p/3doodler-3d-printing-pen-n00ds
Re: 3d Printer?
« Reply #106 on: December 14, 2014, 11:06:05 PM »
Did you see the £100 price tag!
Re: 3d Printer?
« Reply #107 on: December 15, 2014, 10:31:33 AM »
Cheaper than a £1000 printer
Re: 3d Printer?
« Reply #108 on: December 15, 2014, 01:09:29 PM »
This is the video of the bridge of torture!
Not thinking of retrying this anytime soon but any observations why it all went wrong would be helpful!
Actually this first bridge test, I'm surprised that it actually recovered from total chaos, normally things go from bad to worse!
http://youtu.be/_q7uOdarWQs
Offline Cobs
Re: 3d Printer?
« Reply #109 on: December 15, 2014, 01:28:43 PM »
Depends if its before or after Godzilla got stuck in it :)
Looks temperature related or clogged up?
Looking at it again i would tell it to go to the end of the block before putting the bridge across the 2 blocks, looks like it missed? the edge of the block and thats when it started going wrong ... maybe needs some support there?
« Last Edit: December 15, 2014, 02:00:40 PM by Cobs »
Re: 3d Printer?
« Reply #110 on: December 15, 2014, 02:11:33 PM »
Yes that was my conclusion too, a weird way of going about it! I don't know if that was due to the original part or the gcode generation in the program I use, but being a 3rd party test piece any deliberate tweaking would have been looked on as cheating I suppose!
Edit: Sorry cobs, didn't explain that it was a bridging test, purposely no support!
If I was actually going to print that I would have done it on its side or with support.
« Last Edit: December 15, 2014, 02:49:56 PM by bigMouse »
Re: 3d Printer?
« Reply #111 on: December 15, 2014, 08:03:07 PM »
I have a few ideas that may improve the result of the bridge test.
I don't know if you have a fan on, but slowing it down+more extrusion would definitely benefit it.
The logic behind slowing it down is obvious, but for anyone who hasn't printed before its because if its going slower over the gap the slower it goes the longer it spends holding the first strands over the gap in their correct places, allowing them to spend more time solidifying into the right spot. A bit more extrusion may help, as I am not sure if the minor added weight would counteract or be less than the minor added strength due to the extra material per line.
Increasing or decreasing the fan could help but you would have to find out by trial and error. Too much fan could push the first strands farther down, but too little fan could allow the filament to spend more time cooling and therefore have more time to sink down. Basically if you want to find out you would have to test a few different fan speeds along the range of it until you find the one that gives the best cooling:push ratio. Also I could not tell if the bottom of the bridge was flat and rectangular or not, but if it is flat and some sort of rectangle it will bridge the gap easier as the filament would just be going straight across, not getting pulled left and right or forwards and backwards as the bottom design changes.
Re: 3d Printer?
« Reply #112 on: December 15, 2014, 08:51:51 PM »
Imported the stl into cad and the beam is rectangular 5mmX 1 mm
Re: 3d Printer?
« Reply #113 on: December 20, 2014, 01:56:33 PM »
Made a second attempt at the bridge, think this was  pretty good, although a bit coarse! layer height 0.25mm, nozzle temp 190c, bed temp 60c, print speed 50mm/s. The thing that made the big difference was dropping extruder temp.
Re: 3d Printer?
« Reply #114 on: December 20, 2014, 08:37:26 PM »
its away
my first print
Re: 3d Printer?
« Reply #115 on: December 20, 2014, 09:02:43 PM »
Looks promising Martin!
Like the colour too!
Try using "no support", and "no platform adhesion type" in Cura!
You will get it off the table easier then!
Re: 3d Printer?
« Reply #116 on: December 20, 2014, 09:31:11 PM »
ive done some reading and I had my first layer to close for pla also should be 02mm for buildtak , and I had 0.1mm
Re: 3d Printer?
« Reply #117 on: December 21, 2014, 06:46:01 PM »
printed this last night came out pretty well  need to get hang of what needs support and what doesn't
one piece is a ship from elite an old 80s game a cobra mkiii
and thought id make a working steam engine so started printing combustion chamber , the piston fell over near end prolly needs support or a raft
Re: 3d Printer?
« Reply #118 on: December 22, 2014, 06:12:39 PM »
This printer on kickstarter seems pretty awesome! Check it out if you're interested:
https://www.kickstarter.com/projects/1122205541/overlord-3d-printer-multi-color-smart-stylish/description
Re: 3d Printer?
« Reply #119 on: December 22, 2014, 11:50:21 PM »
few more prints
  • Other »
  • 3d Printer?
Page created in 0.503 seconds with 21 queries.
