It comes with pre-configured ESC with latest Firmware,
Gold connectors pre-soldered on ESC,
pre-cut Servo horns and a custom Prop stopper - Everything you need for ARTF!
So does any other ESC! and fw is free
Guess you mean standard gold plated connectors, like $3 for a bag full!
Yes well I'm still trying to figure out how all this could even approach a fraction of £294
Go with a Stryker One Impact and you can throw it in the garbage. Stryker also don't likes extra weight. Will fly like a pregnant Cow with FPV gear.....
Quote from: MatthiasC on January 20, 2015, 04:51:58 PM Go with a Stryker One Impact and you can throw it in the garbage. Stryker also don't likes extra weight. Will fly like a pregnant Cow with FPV gear..... I have flown my Stryker FPV, it flew great, in fact I've even flown my Micro Stryker FPV I have FPV gear that weighs less than 20 grams inc camera tx and antenna, I don't think that will make any Stryker fly like a cow let alone a pregnant one I'm going to guess that you've never flown a Stryker Oh yes and my Stryker has had more heavy duty crashes than any other aircraft I've had, mainly because I bought it long before I was ready for such a plane, but it is still in solid working condition and has had no replacement parts at all despite having been snapped almost in half latterally
My definition of FPV is a complete gear (LR UHF Receiver, vTX, OSD, FPV Cam and a Recorder Cam). You have to compare same stuff togehter. When you look at our Wipeout, it also carries that gear.
I dont think your Stryker flies like this with all thet gear (specially a GoPro at the front).
And if you dont straighten the Stryker with tape or similair it will brake at several Points don't tell me everything i glueg my strykers together so many times...
Watcho our Wipeout Series #3 Video and you can see how durable our wing is.
Quote from: MatthiasC on January 20, 2015, 10:52:02 PM My definition of FPV is a complete gear (LR UHF Receiver, vTX, OSD, FPV Cam and a Recorder Cam). You have to compare same stuff togehter. When you look at our Wipeout, it also carries that gear. Well that may be your definition, however your definition doesn't count, what really matters is each individuals definition of FPV Quote from: MatthiasC on January 20, 2015, 10:52:02 PM I dont think your Stryker flies like this with all thet gear (specially a GoPro at the front). My Stryker doesn't need all that gear Quote from: MatthiasC on January 20, 2015, 10:52:02 PM And if you dont straighten the Stryker with tape or similair it will brake at several Points don't tell me everything i glueg my strykers together so many times... I've flown the same Stryker for nearly 3 years now despite it being my most often crashed plane, it's still solid as a rock, flies fast and stable too Quote from: MatthiasC on January 20, 2015, 10:52:02 PM Watcho our Wipeout Series #3 Video and you can see how durable our wing is. To be reasonable value comparatively your's would have to last at least 3 times that (9 years) due to it's huge price tag
some sort of specialised process
claiming your own specially modified firmware, You are a fraud!
re-labeled hardware require
and we are only talking about 1 ESC, 1 Motor, 2 servos here!
that I can see is your attempt to wipe out anybody's bank account
So you claim your wing is indestructible? Then I assume you will honour that statement and replace free of charge anyone who breaks one?
