  • Long coax cable between UHF tx and antenna?
Spanky 5 Dropped From the Sky by Brodjackella
[Today at 12:26:51 AM]
spring is in the air by mark1975
[March 22, 2015, 09:11:33 PM]
Pixhawk on quadcopter by Tecnic
[March 22, 2015, 02:41:28 PM]
Scottish Borders Counties Rally Aerial Fotage HD by Mancini
[March 22, 2015, 01:58:11 PM]
[March 21, 2015, 01:00:48 PM]
Gopro Live out through switcher video problem by xxpitt
[March 21, 2015, 11:58:13 AM]
Mark having a fly with my 270 miniquad by Brodjackella
[March 20, 2015, 12:02:02 PM]
naze ppm mapping by Brodjackella
[March 20, 2015, 11:57:47 AM]
Author Topic: Long coax cable between UHF tx and antenna?  (Read 684 times)
« on: August 07, 2014, 05:13:32 PM »
Howdy pilots!  I'm new here And not very knowledgeable at all On FPV flying and so I have a question I'm hoping you good fellas here could help me with..
Should I choose to add a good few meters of high grade coax cable from my UHF tx and its antenna. Is that likely to cause me a great deal of signal loss?
'really hoping I could mount the antenna up high on a nice big pole and Connect it to my Tx so I could possibly fly from indoors.
Any help would be appreciated.
Cheers!
Gav
Re: Long coax cable between UHF tx and antenna?
« Reply #1 on: August 07, 2014, 07:03:45 PM »
 Radio Shack Tandy Cable RG-58 which is probably what is sold here:
http://www.hobbyking.com/hobbyking/store/__21270__RG58_Patch_Cable_SMA_Female_to_SMA_Male_5_Meter_.html
This will lose about 1.5db (or 1w in 0.7w out)
The loss is linear with length so
http://www.hobbyking.com/hobbyking/store/__21271__RG58_Patch_Cable_SMA_Female_to_SMA_Male_10_Meter_.html
This will lose about 3db (or 1w in 0.5w out)
There are other more exotic cables around but the best solution would be to have the Tx near the Antenna and make the long leads connect the controller (in the house) to the rf Tx (on or near the roof) These long leads would be prone to rf interference, would need to tried and see the results...
« Reply #2 on: August 07, 2014, 08:41:02 PM »
you are better off leaving the antenna on the UHF tx module and extending the PPM wires in between the transmitter and the UHF module instead, although both work fine
« Reply #3 on: August 07, 2014, 09:29:08 PM »
Oh right I see, I'm sure I did think about that. I guess I dismessed it for reasons like.. the module has ubs ports and a few more ports ect that I don't yet understand. Thought It would be handy to have this indoors or at least have easy access to it. And I'm not sure what the PPM wires look like or how many wires there is . Or if I could buy and extender cable of sorts. Ill be sure to check that out guys thanks for the help!
Gav
« Reply #4 on: August 07, 2014, 09:33:59 PM »
I use ezuhf the usb port is only used for flashing the firmware, there is a lo/hi power switch on the module though which could be used in flight if you start getting loss of signal, however i ezuhf you can actually assign this to a spare channel switch on the tx so you really do not need to be sat next the the uhf module at all. ezuhf used a S-video type cable where it plugs into the uhf module and servo pins the other end so I just bought a 4m s-video lead cut one end off and crimped on my servo connectors (you could solder a servo cable on if you dont have a crimper) most uhf units have a servo type connector both ends so even easier.
« Reply #5 on: August 07, 2014, 09:41:05 PM »
Oh this is great news! I will be using the same EzUhf module kindly suggested By Xxpitt , Do you use an extension of some sort yourself then bud?
Cheers!
EDIT . Oh sorry You clearly do..
« Last Edit: August 07, 2014, 09:43:14 PM by MK1G4V »
« Reply #6 on: August 07, 2014, 10:19:09 PM »
there are 2 ezuhf modules
one is a JR module type which xxpitt has, i have the original unit (picture below)
« Reply #7 on: August 07, 2014, 10:25:44 PM »
Oh right geeez I see, hmmmm
  • Dot Guests: 41
  • user fpvmodel
Page created in 0.61 seconds with 22 queries.
