  • 1.2 gear loosing my sanity
What did the postman bring you today? by gavnthat
[Today at 10:52:48 PM]
[Today at 12:52:16 PM]
Author Topic: 1.2 gear loosing my sanity  (Read 724 times)
« on: July 06, 2014, 04:03:34 PM »
I am losing my sanity right now, I bought a pair of yellow label VTX's http://www.dronesvision.net/en/wireless-av/62-racewood-12ghz-500mw-wireless-av-transmitter-yellow-label.html
And this lawmate Rx, which is listed as compatible.  http://www.dronesvision.net/en/wireless-av/1759-modified-lawmate-900mhz-13ghz-wireless-16ch-fpv-receiver.html
I have wired my quad up today and I get no video. I have tried both my Vtx's and 3 different known working cameras.  The wiring is definitely right.  I have tried different channels to no avail.
There is some kind of signal getting through to my goggles, if I unplug the quad I get standard static in my goggles but if I power it up I get some different static almost like the Lawmate Rx is on the wrong channel.  But its not.  I am starting to think that I have a faulty bloody Rx.  Is there anyway I can test my lawmate? I dont want to have to order another one and find out I have the same issue
« Last Edit: July 06, 2014, 04:16:29 PM by papa_lazerous »
Re: 1.2 gear loosing my sanity
« Reply #1 on: July 06, 2014, 06:12:23 PM »
Just a wild guess but if they are fatsharks, have you got the switch turned to internal Rx?
« Reply #2 on: July 06, 2014, 06:13:59 PM »
Don't have interal on mine. I don't get a picture on my 7" LCD either, but it blue screens so I used goggles to see what was going on
Sent from my SM-N9005 using Tapatalk
« Reply #3 on: July 06, 2014, 06:57:58 PM »
have you got it switched to B on the vrx?
« Reply #4 on: July 06, 2014, 07:12:11 PM »
Yes Ben I'm going to go through every channel later just in case though. I'd swear the vrx is faulty. I've got no way of testing it though
« Reply #5 on: July 06, 2014, 07:57:20 PM »
Yeah go through every channel on vrx and then again on other switch a or b. Also sure yellow only has 2 or 3 compatible channels so make sure you've got the right one. I fly yellow racewood and lawmatev together
« Reply #6 on: July 06, 2014, 08:00:19 PM »
The yellow should have 3 channels that are compatible. I'm going to have a look at it in a minute and go through all the channels
« Reply #7 on: July 06, 2014, 10:09:14 PM »
Okay I have found the issue!  the plug on my camera had the Video and +12V wire switched in the socket!! Its a brand new camera and I used the cable supplied without checking it.  Sodding Chinese quality control, I fixed the wiring and the camera works fine, but I think its shagged my Vtx, I now get an image but its black and white and very fuzzy and almost no range half a metre at most.  And the worst part is I tried both my Vtx's earlier and both have the same symptoms.  First time I have had issued like this hopefully will be the last
« Reply #8 on: July 06, 2014, 10:14:19 PM »
hahah scrub that! i have it working.  yes i had the wiring wrong due to a bad cable but my vtx is on channel 2 which is 1100mhz but my vrx is on A-6 which is 1280 which means i have a blue label vtx!!!!
« Reply #9 on: July 06, 2014, 10:22:23 PM »
they do actually have a coloured label on the vtx itself, i have had 3 or 4 and the label has been the colour i ordeded
« Reply #10 on: July 07, 2014, 09:10:17 AM »
The label is yellow but only has 1 channel that the vrx can receive and that's a blue label channel. It shouldn't matter I'm just happy I got it fixed. Never have I ever had this much grief on a setup. What done me in was that it was two problems together not just one.
« Reply #11 on: July 07, 2014, 11:46:17 AM »
all's well that ends well, thats sloppy service from drones vision though might be worth sending an email, see if they'll send you another out for free, probably not but worth a try
« Reply #12 on: July 07, 2014, 12:53:23 PM »
I'm just glad it's sorted. Just got to set up my osd and my naze and program my taranis and I'm golden
« Reply #13 on: July 07, 2014, 05:10:38 PM »
Probably a manufacture problem TBH so maybe not drones fault maybe they will offer you store credit as a form of compensation.
« Reply #14 on: July 07, 2014, 08:17:04 PM »
The vTx gets bloody hot. Anything I need to do or is the airflow enough in flight to cool it?
  • Dot Guests: 36
  • user mutley2
[Today at 07:17:14 PM]
Page created in 0.764 seconds with 23 queries.
