  • RMRC 1.2ghz 400mw Vs Racewood 1.2ghz 500mw
Best FPV combinaison for reduced latency by alexcherpi
[Today at 09:29:57 AM]
Mini Skyhunter, a nice FPV airplanes by tellypan
[Today at 09:18:44 AM]
[June 04, 2015, 09:01:00 PM]
Flyingwings Venturi Evo build by MrBen
[June 04, 2015, 09:00:33 PM]
[June 04, 2015, 02:30:52 PM]
[June 02, 2015, 09:32:05 PM]
Happy Flyers on tour Part 1 - Millau Viaduct FPV with nasty surprise by MatthiasC
[June 01, 2015, 12:06:01 PM]
[June 01, 2015, 11:56:48 AM]
[May 28, 2015, 04:31:42 PM]
Spanky 5 Action by gavnthat
[May 27, 2015, 09:39:49 PM]
GemFan killers: DragonFly Bulletproof propellers for Mini Quads by fpvmodel
[Today at 11:09:59 AM]
Author Topic: RMRC 1.2ghz 400mw Vs Racewood 1.2ghz 500mw  (Read 1110 times)
« on: June 28, 2014, 08:27:45 AM »
Well I thought I would try one of the RMRC vtx, it came very weighty at 60grams in its green aluminium heatsink/case now its been removed its very similar size and weight to the standard racewood 1.2ghz 500mw unit. The plugs are identical too so I will be testing these back to back and get some GS footage from both to compare image quality.
Thats the RMRC on the left and the Racewood on the right
« Last Edit: June 28, 2014, 11:12:03 AM by MrBen »
Re: RMRC 1.2ghz 400mw Vs Racewood 1.2ghz 800mw
« Reply #1 on: June 28, 2014, 08:35:25 AM »
nice work ben will be interesting to see which out performs the other. fingers crossed racewood comes out on top as thats what i have
« Reply #2 on: June 28, 2014, 08:44:10 AM »
I hear the rmrc has better image quality dave which is why i wanted to try one, I was surprised to hear you say you though the lawmate picture was better that the racewood as I cant really tell any difference.
« Reply #3 on: June 28, 2014, 08:53:06 AM »
I couldn't tell the difference between sunsky vtx (the heavy green one) and the lawmate.
With a sunsky/rmrc out of its green case beware that the antenna connector will have little support, especially as they are fitted with the large clumsy standard antenna. very easy to damage the vtx in a crash! In it's green case its almost indestructible...
« Reply #4 on: June 28, 2014, 09:01:09 AM »
yes indeed there seems to be some support on the racewood! maybe I will make a mini dipole using a coax pigtail just so it cant take a direct knock via an attached whip antenna!
« Reply #5 on: June 28, 2014, 10:51:03 AM »
What frequency do you fly mini on Ben 1160? Make a small antenna extention for minis so you can put tx inside with short bendable extention going to an antenna bracket , antennas are all I'm worried about with spanky vtx antenna has had a a few knocks , I'm prolly going to make a small vee for vtx and a lighter UHF antenna than I have now
« Reply #6 on: June 28, 2014, 11:07:32 AM »
800mw ? ben  is this 500mw one if so its actually rated@ 700mw  i believe
« Reply #7 on: June 28, 2014, 11:11:00 AM »
yes sorry its 500mw isnt it will correct it above, thanks
« Reply #8 on: June 28, 2014, 11:13:27 AM »
Quote from: bigMouse on June 28, 2014, 08:53:06 AM
hundreds of crashes (literally)on quads with mine pointing upwards so homemade  cut pigtail antennas take full impact with no damage to vtx sma point. destroyed a few antennas though..
the 400 is a way better picture,better colours and sharper picture than my lawmate 1w jobbies,again witnessed through hundreds,possibly thousands of flights..no idea if better than the racewood ones as zero flights using one.
Re: RMRC 1.2ghz 400mw Vs Racewood 1.2ghz 500mw
« Reply #9 on: June 28, 2014, 11:47:42 AM »
I just received the 500mw racewood, it's already installed into my Skywalker wing, so I'll watch this with interest, see how you get on with the comparison
« Reply #10 on: June 28, 2014, 06:54:41 PM »
Yeah I though I had better picture with racewood but might of been the different channel I was on. Or maybe I was just excited to be flying a mini it was clouding my judgment
« Reply #11 on: June 29, 2014, 01:55:13 PM »
Is this lawmate 500mw ,  there is a resister inside that's at the bottom of the case between ground and video signal if case gets flexed it can break solder point that can make lawmate picture washed out I've had it happen many times, when it breaks the joint you can tell by putting pressure on bottom of case and it shows movement , this might be why people are seeing diff results
« Reply #12 on: June 30, 2014, 05:23:23 PM »
Well it turns out the VTX I had on my spanky was only outputting 40mw, Martin brought along his immersion rf power meter and we tested it, now I cant remember if this was the one that was on the QAV crash as when that was recovered the VTX had the antenna ripped off, will do another comparison test on another day with a different racewood as I have 3.
  • Dot Guests: 24
Lightbridge, Phantom, GoPro, Black Pearl by loganj13
[June 04, 2015, 09:34:15 PM]
Page created in 1.587 seconds with 26 queries.
