  • Multirotor power distribution board with 12v and 3-20v (adjustable ubec)
[May 08, 2015, 05:03:02 PM]
[May 07, 2015, 09:14:47 AM]
[May 06, 2015, 01:48:41 PM]
[May 06, 2015, 09:22:18 AM]
[Today at 08:47:04 AM]
[May 07, 2015, 09:24:16 AM]
Author Topic: Multirotor power distribution board with 12v and 3-20v (adjustable ubec)  (Read 1847 times)
« on: June 25, 2014, 05:28:19 PM »
this looks good
http://www.hobbyking.com/hobbyking/store/__55556__Quanum_Power_Distribution_Board_and_Dual_UBEC_In_One.html
The Quanum power distribution board is a 3-in-1 device that simplifies even the most complicated multirotor builds.
The PDB has two built in super clean 5A UBEC’s one set at 12V for your FPV gear and the other adjustable from 3-20V perfect for powering your flight controller or other gear.  The 2oz copper double sided PCB can handle 80A of power and the Ubec’s can take up to a 6s. There are dual output pads for the Ubecs and 8 positive and 8 negative pads for the power distribution. The overall size is the standard 52mm with 45mm holes for drop in mounting to most multirotor frames.
Simplify and tidy your multirotor builds, well increasing reliability and decreasing weight with the new Quanum 3-in-1 power distribution board.
Specs:
Amps: 80A
Voltage: 6s
Weight: 11g
Mounting: 45x45mm holes square (3mm holes)
Ubec 1 output: 5A 12V
Ubec 2 output: 5A 3~20V adjustable
Re: Multirotor power distribution board with 12v and 3-20v (adjustable ubec)
« Reply #1 on: June 25, 2014, 05:59:01 PM »
bloody good idea . like it
« Reply #2 on: June 25, 2014, 10:10:13 PM »
ideal for my qav that is, with 5v vtx and 12v cam
« Reply #3 on: June 25, 2014, 10:13:58 PM »
think i will be ordering one when i get my esc's
« Reply #4 on: June 25, 2014, 10:23:01 PM »
actually would be daft on qav as don't need the pdb just the becs for fpv gear. they should make a 12v and adjustable voltage reg duo just for fpv gear, same as this but without all the motor solder pads would be awesome
« Reply #5 on: June 25, 2014, 10:26:24 PM »
you dont have to use it as a PDB dave its same size as a naze or cc3d so not too big really
« Reply #6 on: June 25, 2014, 11:39:46 PM »
looked bigger than naze, watched the video and he showed 2 boards a small one then that one, looked kk2 size. i know you don't have to use it as a pcb
« Reply #7 on: June 26, 2014, 08:33:32 PM »
Be careful, this won't fit the Spanky hole layout, as xxpitt says, it's kk2 size...
« Reply #8 on: June 28, 2014, 06:30:24 PM »
I have one of these on my rctimer spider, makes the wiring much easier, the adjustable bec puts out just under 12v max on 3 cell. I tried running my fpv gear from the adjustable bec but got video loss as the voltage dropped. If you run 4 cell its a great way of running everything off one battery.
« Reply #9 on: June 28, 2014, 06:49:11 PM »
If your running 3s you can piwer the 12v stuff straight off the lipo anyway
« Reply #10 on: June 28, 2014, 07:02:55 PM »
I know but thought if I ran it off the bec it wouldn't be affected as much by the voltage sag and would stop me needing a seperate batt for the fpv gear. Trying to avoid going to 4s as I have quite a few 3s batts but my quad is pretty heavy and flight time is suffering.
« Reply #11 on: June 28, 2014, 07:10:00 PM »
I fly one 3s lipo on my mini and it powers the cam and vtx aswell as the quad. Doesnt seem to be effected by lag and still get picture when my lipo is flat
« Reply #12 on: June 28, 2014, 07:36:21 PM »
I Run my mini all off 1 batt as well and it doesn't affect it at all even when I start to lose power for flying I still have a good picture ,but on the spider its ok for first few minutes then the voltage sag kills the video, I have a brushless gimbal, gps, osd, video switcher, Bluetooth, as well as the fpv gear so I think all this must drain the battery more also I have rctimer motors on it which I don't think are that efficient. The battery's are 30c but I think it needs more. It doesn't get flown that much nowadays as minis are loads more fun and you can fly them virtually anywhere.
[May 06, 2015, 09:02:25 PM]
Page created in 0.47 seconds with 22 queries.
