  • Selling »
  • Traders Section »
  • Naze 32 Acro £21.95 ----- Blue Tooth Module £9
[April 18, 2015, 10:06:11 PM]
Pages: [1] 2 3 4
Author Topic: Naze 32 Acro £21.95 ----- Blue Tooth Module £9  (Read 5541 times)
« on: March 17, 2014, 05:11:58 PM »
I have received a batch of the latest revision v5 Naze 32 Acro boards
Price is £21.95
P&P is £2 for 1st class recorded
Awesome flight controller flies like its on rails, very very impressed with it and I have flown Naza, Copter Control, KK2.0, Copter Control 3d, Wookong and this is my favorite so far! Demo video shows how smooth it can be but it is also very acrobatic too and has some really great features like 'horizon' mode (where you can still do flips and rolls but it auto levels when you centre sticks. For mine I bought a bluetooth adaptor from ebay for £7 and I have an app on my android phone for adjusting all the settings they can also be adjusted with the GUI on a PC. So far all I have needed to do is tweak yaw PID and up rates a little.
Quadcopter footage of Burtonwood Omega DESTRUCTION!
I also found this video very helpful
How to setup a Naze32 Acro / Funfly Flight Controller
Acro Naze 32 flight controller
These come with all needed headers, NOT soldered to the board.
Included: 1x AcroNaze32 rev5, 1x 2x5 header, and1x 3x6 right angle header
Mini Acro Flight Controller 「なぜ」 (pronounced "Naze").
36x36 mm
5.3 grams (no headers, 7.3 grams with)
2000 degrees/second 3-axis MEMS gyro + accelerometer (MPU6050)
Flexible motor outputs, support various airframe types -
Quad/Hexa/Tri/Bi/Y4/Y6/Octo/Camera Gimbal. (Default is Quad-X)
Up to 8 ch RC input - supports standard receivers (PWM), PPM Sum receiver (FrSky, etc), or Spektrum Satellite receiver.
Built in FrSky telemetry inverter (shared w/main port)
Battery voltage monitoring
Modern 32-bit processor running at 3.3V/72MHz (STM32F103CB).
16Mbit onboard SPI flash
Onboard MicroUSB for setup and configuration
LEDs so bright, they will blind you
MultiWii-based configuration software for easy setup
rev5 hardware
Made in JAPAN
Designed for use with small indoor or small to mid-sized outdoor multirotor craft, or as a standalone camera stabilizer, the Naze32 flight control is simple to setup, with configuration based on the familiar “MultiWii” software.
Discussion thread: http://www.multiwii.com/forum/viewtopic.php?f=22&t=2387
Download User's Manual for rev5. User's Manual for rev4.
Configuration software - Chrome Baseflight Configurator (preferred)
https://chrome.google.com/webstore/detail/baseflight-configurator/mppkgnedeapfejgfimkdoninnofofigk
Can also use 2.3 or newer version of MultiWiiConf (Java-based) from http://code.google.com/p/multiwii/downloads/list.
Software is open-source! Code repository at
https://github.com/multiwii/baseflight .
« Last Edit: June 20, 2014, 07:07:23 PM by MrBen »
Offline Dantian
Re: Naze 32 Acro - Awesome flight controller
« Reply #1 on: March 17, 2014, 06:06:08 PM »
I may as well grab one off you, but can you solder the pins on for me as I cant be arsed ;)
Will Paypal you the money.
Phil
QAV400
QAV540G
Zephyr II
TwinStar 2 (in build)
« Reply #2 on: March 17, 2014, 06:18:27 PM »
pm sent Phil
« Reply #3 on: March 17, 2014, 07:44:42 PM »
I will also be selling compatible Blue Tooth adaptors for NAZE board these will be pre-configured ready to just plug in!
When bought elsewhere these adaptors do not come with the correct BAUD rate set and you would require a USB>TTL adaptor to configure (different from a esc/kk2 flasher)
Pre-configured Naze Bluetooth Adaptor - £9
I have successfully been using Multiwii EZ-GUI and also Naze32 Configurator on my Android phone.
https://play.google.com/store/apps/details?id=com.ezio.multiwii
https://play.google.com/store/apps/details?id=com.naze32.configurator
4 Wires run between the Naze and the BT Adaptor :5v, GND, TX & RX (wires not supplied)
« Last Edit: March 17, 2014, 08:30:05 PM by MrBen »
Offline Dantian
« Reply #4 on: March 18, 2014, 06:09:09 PM »
I'll take one of the BT adaptors off you too Ben , let me know when you have them.
QAV400
QAV540G
Zephyr II
« Reply #5 on: March 18, 2014, 06:55:57 PM »
should be here tomorrow
« Reply #6 on: March 21, 2014, 07:12:04 PM »
Bluetooth Adaptors now in stock too, will include 2 x 10cm servo wires so you can connect it up to Naze
Offline Dantian
« Reply #7 on: March 21, 2014, 08:04:27 PM »
Sent you the money for the bt adaptor Ben.
QAV400
QAV540G
Zephyr II
« Reply #8 on: March 22, 2014, 07:48:00 PM »
Got it Phil, are you flying tomorrow by any chance, your board is all soldered up with BT adaptor wired in too
« Reply #9 on: March 22, 2014, 07:54:10 PM »
look at that service with a soldering iron ;)
Re: Naze 32 Acro £19 ----- Blue Tooth Module £9
« Reply #10 on: April 01, 2014, 09:11:43 PM »
Some useful information :
RC Expo, 0<->1 Just like TX expo on stick input vs rc output curve...can be used in addition to or in place of expo on both ail and elev (0.65 default)
RC Rate, 0<->? Increases stick sensitivity of requested axis roll and pitch rates, 1 is normal (0.9 usual default), increasing it makes any stick input command more gyro roll or pitch rates..like increasing TX throws on both channels
Pitch/Roll Rate, 0<->1 Reduces P pid terms for pitch and roll as stick is moved away from center, making rolls and flips faster...0= no reduction, 1= no pid loop corrections at full stick (totally unstable!)
Yaw Rate, 0<->1 Reduces P pid terms for yaw as stick is moved away from center, making pirouettes faster...0= no reduction, 1= no pid loop corrections at full stick (totally unstable!)
TPA, 0<->1 Decreases roll/pitch P terms above 50% throttle....0 no reduction, 1 reduction to 0....not very useful except in planes where faster, sometimes create oscillations due to increased control surface effectiveness....in a quad, will make it unstable as you punch the throttle
Offline John Sheehy
  • Newbie
« Reply #11 on: April 25, 2014, 08:24:31 PM »
Quote from: MrBen on March 17, 2014, 05:11:58 PM
Price is £21.95
Soldering service for pin headers is £5
Hi MrBen,
I'd like a naze32 with soldering and a bluetooth module.
I make that £35 with postage.
I'll paypal you when you give me the details.
John.
« Last Edit: June 20, 2014, 07:25:13 PM by MrBen »
« Reply #12 on: April 26, 2014, 11:48:05 AM »
Ben - have you got any of these left. If not can you put me down for one from the next batch with Bluetooth please. Let me know bud.
« Reply #13 on: April 26, 2014, 04:05:43 PM »
Quote from: Ant on April 26, 2014, 11:48:05 AM
I have both 'Acro Naze 32' @ £19 as well version with baro and magnetometer which is £39, BT adaptors are £9 postage is £2
paypal is multirotorparts at hotmail.co.uk
« Reply #14 on: April 26, 2014, 04:08:45 PM »
Quote from: John Sheehy on April 25, 2014, 08:24:31 PM
Price is £21.95
Hi MrBen,
John.
Did you get my PM John?
« Last Edit: June 20, 2014, 07:24:55 PM by MrBen »
Pages: [1] 2 3 4
  • Selling »
  • Traders Section »
  • Dot Guests: 27
  • user meluk
Page created in 1.436 seconds with 21 queries.
