  • Batteries & Chargers »
  • 12v from balance plug.
VTOL by xxpitt
[Today at 06:43:21 PM]
[Today at 06:40:37 PM]
[Today at 09:27:15 AM]
[March 25, 2015, 04:57:21 AM]
Author Topic: 12v from balance plug.  (Read 1043 times)
Offline Andy66
« on: January 21, 2014, 03:47:38 PM »
Ok so I want to power my vtx and cam from the balance plug, I've bought a couple of balance plug extensions that I could hack up for this.
Q, so that I get to use the 3cells so no unbalance to the battery is caused do I solder the 3 neg wires together or use only one neg?
Thanks andy
Re: 12v from balance plug.
« Reply #1 on: January 21, 2014, 04:16:01 PM »
just use 2 leads from batt balance leads,black usually far right will be your negative and white(usually) will be your positive,which will give you the 12v needed.white if HK cells is the white 4th along lead.
i'll post a pic for you Andy.
contrary to what people say,very little imbalance will happen but best balance charge after every flight.
using cam and vtx will only use about 0.03 mah after a 6-10 min. flight so easy to rebalance
« Reply #2 on: January 21, 2014, 04:24:12 PM »
are you using 3 cell or 4 cell lipo?
above advice is using a 4 cell lipo
if using a 3 cell lipo,just use black for negative and far lead,4th for positive,this wont imbalance any cells
« Last Edit: January 21, 2014, 04:38:35 PM by brodjackella »
Offline Andy66
« Reply #3 on: January 21, 2014, 05:10:08 PM »
Yes it's 3s battery, so do you mean to connect all black together for 3s?
« Reply #4 on: January 21, 2014, 05:24:44 PM »
no,just use black from balance lead as negative and far one at other end as positive.
Offline Andy66
« Reply #5 on: January 21, 2014, 05:30:08 PM »
Just found this as example, is this what you mean brod?
http://www.readymaderc.com/store/index.php?main_page=product_info&products_id=500
« Reply #6 on: January 21, 2014, 05:32:29 PM »
yes that exactly what you do.
Offline Andy66
« Reply #7 on: January 21, 2014, 05:36:29 PM »
Great thanks brod  :)
« Reply #8 on: January 21, 2014, 06:12:35 PM »
Andy if you have more than one black wire then not all of them are negatives m8 only one of them farthest from red, best check with a multimeter if your unsure you can get them for a fiver and it saves you releasing magic smoke out of your components
Offline Andy66
« Reply #9 on: January 21, 2014, 07:01:03 PM »
I've copied the one in the link and all works well. Thanks guys.
« Reply #10 on: January 21, 2014, 07:20:41 PM »
Why don't you do what you told me to do with the fat shark regulator?
Offline Andy66
« Reply #11 on: January 21, 2014, 07:59:51 PM »
Doesn't work the same way m8
Offline Vass
    • My photography
« Reply #12 on: February 08, 2014, 07:49:39 AM »
Hi guys, I've just moved to 4S lipo's now, so I think my fatshark 250mw vtx will only take up to 13v
Do you all use a ubec on your vtx?
Ta
www.doubleyolk.co.uk
« Reply #13 on: February 08, 2014, 07:51:27 AM »
voltage regulator for 12v however i use a ubec on my 5v lawmate vtx
  • Dot Users: 9
[Today at 07:34:48 PM]
Propellers 15" 17" DFDL, Turnigy, RCTimer CW CCW Multirotor Propellers CHEAP ! by Mancini
Page created in 0.901 seconds with 22 queries.
