  • FPV Funjet
[Today at 11:44:44 AM]
OSD vs DIJ NAZA lite M by Martink1974
[Today at 12:09:33 AM]
MrBens Happy Wings 'Wipeout' Build Thread by xxpitt
[April 26, 2015, 06:09:37 PM]
Spanky5 Race Practise by MrBen
[April 26, 2015, 09:07:03 AM]
[April 26, 2015, 06:46:13 AM]
Hobbyking Durafly Me-163 Komet 950mm FPV Bungee and crash by bigMouse
[April 24, 2015, 07:17:40 PM]
[April 24, 2015, 08:07:18 AM]
Author Topic: FPV Funjet  (Read 2613 times)
mrholozip
FPV Funjet
« on: February 12, 2012, 10:09:37 PM »
I've been dying to compete in the round trip speed challenge, and attempted to soup up a Slipstream 1m, which tore itself to pieces in mid-air.
I wanted to reuse the power system, so bought Funjet Ultra.
The idea was to make it as fast as possible, but yet still carry FPV gear. Managed to just about squeeze everything in. Weighs in at just over 1.2kgs.
Kit List:
  • Funjet Ultra
  • Eflight BL32 EDF motor (capable of bursts up to 1665W)
  • Castle ICE 100amp ESC
  • 7x6 Graupner Carbon Pro
  • 4S 3300 Nanotech Lipo (35-70C)
  • SN555 5v FPV Camera
  • 5.8Ghz Immersion RC TX
  • EzOSD + Current Sensor
  • AR7000 RX + Satellite
Getting started
Power System
Glueing Wings
FPV Gear
Laying out components
Almost finished
mrholozip
Re: FPV Funjet
« Reply #1 on: February 12, 2012, 10:13:08 PM »
Maiden LoS test flight was a bit of a joke though :(
http://www.youtube.com/watch?v=dY6eq6bmeSw
Re: FPV Funjet
« Reply #2 on: February 13, 2012, 01:33:54 AM »
Like that plane.Try to throw flat ,should be easier.
waiting to see FPV form it. ;D
Re: FPV Funjet
« Reply #3 on: February 13, 2012, 05:58:29 AM »
what happened? did it just get too far away, was it tail heavy or what? any damage?  :o
Re: FPV Funjet
« Reply #4 on: February 13, 2012, 09:28:53 AM »
confused here as to what happened...they can't half shift :)
mrholozip
FPV Funjet
« Reply #5 on: February 13, 2012, 08:04:20 PM »
Looking at it closer after the crash one of the elevons was torn with no surrounding damage.
I replaced the original pushrods with thicker ones, and it looks like they're binding and pushing the elevons slightly sideways - guess it caused the foam to tear.
Was flying great on launch (managed to recover from the throw and torque roll easily).
At the point it started circling I had little to no control. Combination of bad luck and poor job putting it together.
I'll learn one of these days.
Almost airworthy again now though thanks to shit loads of CA, gorilla glue, and three carbon spars over the join.
Re: FPV Funjet
« Reply #6 on: February 13, 2012, 08:14:28 PM »
sorry to hear the maiden didn't go as planned but sounds like you will be. back in the air in no time.
Offline Chris R
  • Mr Awesome
Re: FPV Funjet
« Reply #7 on: February 13, 2012, 08:15:44 PM »
Turn your throws down to about 5-7mm up and down, launch at 30 degrees with 60% throttle. have COG 1/2" forward of COG marks.
mrholozip
FPV Funjet
« Reply #8 on: February 13, 2012, 08:30:20 PM »
Ta Chris - throws were a little higher than that, though I did have a fucktonne of expo. Will reduce rates and reduce expo a touch before next flight I reckon.
Was our first attempt at launching, and wasn't sure on best method on such a heavy setup - resorted to lobbing it as hard as possible into the wind. Will try getting it around 30 degrees next time with less force.
Re: FPV Funjet
« Reply #9 on: February 14, 2012, 04:25:11 PM »
Wow, ive only just seen this. Cant wait to see it FPVed. Very nice. Unfortunate on the maiden tho.
Re: FPV Funjet
« Reply #10 on: February 15, 2012, 12:24:22 PM »
Quote from: mrholozip on February 13, 2012, 08:04:20 PM
Did you strengthen the hinge at all? At that power I would get some strong tape across the top and bottoms at the very least.
Offline chrisallen649
Re: FPV Funjet
« Reply #11 on: February 15, 2012, 12:36:13 PM »
had the same problem with my stryker f-27q. With little models like this it seems the hinge's are the first thing to give way when at high speed's due to the extra weight placed in the model. Simple fix re hinge, pin the hinge's then use some good old reinforced fibreglass tape it works a treat on mine anyways.
Offline Chris R
  • Mr Awesome
Re: FPV Funjet
« Reply #12 on: February 15, 2012, 01:19:13 PM »
Here a video of my funjet.
http://www.youtube.com/watch?v=jO2OY009vqI
mrholozip
FPV Funjet
« Reply #13 on: February 15, 2012, 04:24:25 PM »
Quote from: londonguy on February 15, 2012, 12:24:22 PM
Unfortunately not - wish I had have done though - would have saved a lot of messing about :(
I'll stick it back on with some re-enforced tape and a couple of dabs of CA.
mrholozip
FPV Funjet
« Reply #14 on: February 15, 2012, 04:25:44 PM »
Quote from: Chris R on February 15, 2012, 01:19:13 PM
Whoa - that's awesome - just watched that via 3G in the airport, Switzerland - prob cost about 9 quid. Worth every penny :-)
  • FPV Funjet
  • Dot Guests: 25
Naza M Complete With Gps by Martink1974
[April 26, 2015, 09:13:33 PM]
[April 24, 2015, 09:18:59 PM]
[April 23, 2015, 07:17:14 PM]
Page created in 1.039 seconds with 21 queries.
