  • Building materials
anyone flying the weekend? by gavnthat
[April 10, 2015, 11:12:36 PM]
Damped Light ESC and Programming by xxpitt
[April 10, 2015, 10:48:47 PM]
What did the postman bring you today? by Tecnic
[April 10, 2015, 01:27:56 PM]
My First 3D Printer Scratch Build by bigMouse
[April 08, 2015, 12:15:23 PM]
[April 08, 2015, 08:53:08 AM]
[April 07, 2015, 09:06:44 AM]
good day at the plot by mark1975
[April 07, 2015, 09:04:41 AM]
Scottish Borders Easter Sunday by Mancini
[April 07, 2015, 01:49:15 AM]
speedway by mark1975
[April 06, 2015, 08:34:48 PM]
From Spain by xxpitt
[April 06, 2015, 11:17:16 AM]
[April 05, 2015, 04:55:13 PM]
Understanding Motor Thrust:Weight Requirements by gavnthat
[April 05, 2015, 04:01:04 PM]
New Flight Case by Martink1974
[April 05, 2015, 01:54:47 PM]
Eagle by Tecnic
[April 05, 2015, 12:53:17 PM]
emax 250 tuning has begun... by mark1975
[April 05, 2015, 11:07:20 AM]
Author Topic: Building materials  (Read 1006 times)
Offline ianholt1
Building materials
« on: November 10, 2013, 08:15:52 AM »
Hi, Anybody know where to get the Blue Foam stuff that people use for scratch building? I have built loads of depron planes in the past but want to build a large wing for FPV use. It seems very easy to gen in the States but cant find it here.
Re: Building materials
« Reply #1 on: November 10, 2013, 09:18:29 AM »
I remember looking for that stuff a while back when I was scratchbuilding...
closest I could find was insulating foam (meant for loft/wall insulation or similar) in B&Q and it wasn't as "cheap" as the stuff the yanks keep going on about so I didn't bother
Offline ianholt1
« Reply #2 on: November 10, 2013, 05:38:51 PM »
Over in the US they seem to find it in the Dollar stores.
« Reply #3 on: November 10, 2013, 05:40:54 PM »
got some sheets form Blackburn models but was few yrs ago
« Reply #4 on: November 10, 2013, 05:45:48 PM »
http://balsamart.co.uk/store/index.php?main_page=product_info&cPath=104_106&products_id=428
Offline ianholt1
« Reply #5 on: November 10, 2013, 07:40:38 PM »
Thanks, looks like an expensive option though.
I work for a builders merchant so I will ask some of our suppliers if they have something. I will post my findings.
Ian
Offline vanmantony
« Reply #6 on: November 11, 2013, 08:37:12 PM »
Ian, I used some foam out of a builders skip, its the insulation type about 7cm thick coverted in foil on one side, Hot wired wing panels out carved to shape and used balsa leading and trailing edges.covered it in Gaint sharks iron on covering (bloody good stuff loads better than solar film)
 cheers tony
P.s guess where I found the foam
« Reply #7 on: November 11, 2013, 08:41:26 PM »
looks sweet! Pro job indeed, are the elevons balsa?
Offline ianholt1
« Reply #8 on: November 11, 2013, 08:50:41 PM »
That rings a bell, I work in tool hire but I remember seeing some thick insulation board somewhere in the yard. I will have a look tomorrow, thanks.
Offline vanmantony
« Reply #9 on: November 12, 2013, 03:14:50 PM »
MrBen, elevons are balsa and as trailing edge is balsa I used 1lt milk carton for hinges cut  lengths  30x10 mm slightly score the middle with screwdriver point to get some flex rough them up with sandpaper and epoxy into slot cut in T/edge and  elevons 4 per side works a treat            cheers Tony
Offline ianholt1
« Reply #10 on: November 17, 2013, 06:57:35 AM »
Found it, At Jewson we can get 2440 x 1220mm sheets of what I think is the same as Blue Core. It is available in 50mm or 75mm thickness for about £18 to £25 + vat and has to be bought in packs of five. It is called floor mate, it is blue and very dense.
Page created in 0.823 seconds with 22 queries.
