  • Videos Section »
  • FPV Videos »
  • longrange attempt at sunset.... turned into a night,are
[Today at 03:44:14 PM]
Author Topic: longrange attempt at sunset.... turned into a night,are  (Read 1447 times)
« on: September 22, 2013, 05:22:19 PM »
I kept going... had loads of battery. I'm 99% sure this is external interference otherwise If it were local I would have seen it up until the 8KM mark, but I didn't.
Really want to get rid of this interference, then I'll be out to 25-30k with the amount of battery I got on this Skywalker.
FPV Long range attempt at sunset turned nightmare! Small | Large
« Last Edit: September 22, 2013, 05:24:12 PM by londonguy »
Re: longrange attempt at sunset.... turned into a night,are
« Reply #1 on: September 22, 2013, 06:42:43 PM »
Does it happen if you fly out a different way? have you tried a different channel? What vrx are you using? Your AHI isnt horizontal.
« Reply #2 on: September 22, 2013, 06:57:20 PM »
how much mah total do you have in your skywalker?
I have single 5Ah LiPo and with my flying style lately, I get around 11-12km flying distance from nearly 4Ah... I guess I just need to change my flying style, learn to be frugal with the throttle stick :)
« Reply #3 on: September 22, 2013, 08:29:48 PM »
epic flight balls of fantasy that flight well done
« Reply #4 on: September 22, 2013, 08:38:17 PM »
Quote from: MrBen on September 22, 2013, 06:42:43 PM
Yeah happened in an earlier flight in which I was pointing in the opposite direction. I am using the RMRC 800mw VTX with stock rubber whip and the optimized patch. Yeah my AHI was going crazy that flight for some reason. Didn't want to reset it in flight so I kept going :)
I checked Amateur TV relay map on 1280mhz, I was in a dead zone according to their map, far away from any of their high power relays.
Quote from: CorporalB on September 22, 2013, 06:57:20 PM
9000mah 4S. In this flight I was using quite a bit more throttle than I have to because it was windy and I wanted to speed the flight up. I normally cruise around 7-9amp.
« Reply #5 on: September 22, 2013, 08:41:40 PM »
What vrx? Try a different channel next time.
« Reply #6 on: September 22, 2013, 08:44:12 PM »
i flew on 1280mhz this time, Not sure which one to try that doesn't shit on anyone else:
this vrx:
« Reply #7 on: September 22, 2013, 08:53:05 PM »
Could be UHF too nr your rx, try lawmate rx as they aren't affected by UHF like others. You can also try 1160.
Offline chrisallen649
« Reply #8 on: September 23, 2013, 11:25:53 AM »
Nice flight london guy and respect for continueing with interference. I can see a sly distance contender in the making. nice job well done :-)
« Reply #9 on: September 25, 2013, 12:24:43 PM »
nice flight londoguy !!...
try lower frequency.
« Reply #10 on: October 01, 2013, 10:13:10 AM »
Woohooo! Thanks for the suggestions to try a lower frequency... I did and went for a flight yesterday on my day off and managed to go 10KM in my usual spot with perfect picture all the way. I didn't get a single black bar, a single cut out, no interference what so ever. It was literally the perfect flight. So I know my video was good to at least 12km, and judging by the quality of the image (inbetween frames of interference) I'd say it would be good for another 5-6km at least. Distance wise the Skywalker is good for 45km.
So now I'm all ready for the flight I have been obsessing about for the past 3 months day and night... going off-shore to fly over the wind-farms off the coast of Kent. There are two large arrays which depending on launch point will be around 13-14km away.
I will be watching the weather over the next few weeks, really want to get this done before winter sets in proper.
http://i.telegraph.co.uk/multimedia/archive/02609/londonarray2_2609391b.jpg
« Reply #11 on: October 01, 2013, 12:51:26 PM »
that's gunna be brave..
Offline einstein00
  • Newbie
« Reply #12 on: January 07, 2015, 08:35:01 AM »
Quote from: Dusty on September 22, 2013, 06:57:20 PM
So, which low frecuency is running ok ?.  and of course, very nice flight :), congratulations
« Last Edit: January 07, 2015, 08:40:42 AM by einstein00 »
  • Videos Section »
  • FPV Videos »
Page created in 1.185 seconds with 21 queries.
