  • TxRx problem
[Today at 03:44:14 PM]
Author Topic: TxRx problem  (Read 694 times)
Johnny
TxRx problem
« on: August 01, 2013, 10:10:42 PM »
I think I have a problem anyway! I am an owner of a Futaba T6X (Field Force 6) TX on 35Mhz FM and a 6ch futaba rx which works perfectly fine with it. I did however, buy a second hand 8ch rx called a Futaba FP-R138DF and a second set of crytsals.
The rx does not seem to work properly. When the tx is turned on, the rx moves a servo a "step" then stops. On sensor test on a kk2.0 board, there is a quick value when the tx is turned on then it has "No signal" written in place again.
I tried the crystals from my working 6ch tx and still no luck. Is the rx duff or am I doing something silly?
Re: TxRx problem
« Reply #1 on: August 03, 2013, 08:38:45 AM »
The Futaba FP-R138DF is PPM, needs a ppm xtal(white), and in the tx mode setting set to ppm.
You didn't say what your other Rx is? if its a Futaba FP-R138DP then it would be pcm, needs a pcm xtal(orange), and in the tx mode setting set to pcm.
Johnny
Re: TxRx problem
« Reply #2 on: August 03, 2013, 11:11:58 AM »
Solved :). Thanks.
  • TxRx problem
Page created in 0.731 seconds with 22 queries.
