  • Ants flipping quad
[Today at 09:48:51 PM]
[Today at 04:55:13 PM]
Understanding Motor Thrust:Weight Requirements by gavnthat
[Today at 04:01:04 PM]
New Flight Case by Martink1974
[Today at 01:54:47 PM]
Eagle by Tecnic
[Today at 12:53:17 PM]
emax 250 tuning has begun... by mark1975
[Today at 11:07:20 AM]
[Today at 09:54:22 AM]
oneshot damped light by gavnthat
[Today at 07:35:33 AM]
Guilty until proven innocent around here by gavnthat
[Today at 07:28:33 AM]
Beginner seeking some support :) by ash.nand@outlook.com
[Today at 02:38:21 AM]
kickstarter project by tommyd
[April 04, 2015, 10:10:01 AM]
vortex pre-order by xxpitt
[April 04, 2015, 09:36:58 AM]
Which wing is the best to buy for fpv by bigMouse
[April 04, 2015, 09:12:38 AM]
Tested my 2.4Ghz Radio Control to over 6 miles today by Tecnic
[April 03, 2015, 08:03:05 PM]
20a sunrise slim esc by xxpitt
[April 03, 2015, 02:03:01 PM]
Author Topic: Ants flipping quad  (Read 1411 times)
Ants flipping quad
« on: July 01, 2013, 10:21:53 PM »
Ok so i rebuild my quad and was eager to get out FPVing  ;D
I was having a reasonable flight when the thing just flipped over and crashed ! Voiltage was OK at 3.9v per cell after the crash. In my eagerness to get out flying i hadnt recalibrated the sensors on the KK but surely if that was out it wouldnt have flown for 3mins??
Broke all four props and thats all but i dont want a repeat performance. Any ideas?
http://youtu.be/94xXxxcDrJo
Hoversight
Re: Ants flipping quad
« Reply #1 on: July 01, 2013, 10:45:25 PM »
Fault symptomatic of a short circuit to an ESC control cable! And do I hear a servo on that quad ?
« Reply #2 on: July 01, 2013, 10:50:07 PM »
Yeah stinks of dodgy connection somewhere, I'd start by looking at the back right motor/esc first
Hoversight
« Reply #3 on: July 01, 2013, 11:23:21 PM »
To reduce the likelihood of a repeat performance do what you can to minimise cable chaff and examine all exposed insulation after a crash. Expect  shards of broken blades to cut something somewhere.
Hoversight
« Reply #4 on: July 02, 2013, 12:57:46 AM »
And you did replace that plate you drilled into right?
« Reply #5 on: July 02, 2013, 09:11:10 AM »
Thanks for the comments .
I had a spare lower board so used that. Does it sound as if there is a servo on board ? because there isn't .
Also should I disconnect the red lead from the esc on motor 2,3 and 4?
Hoversight
« Reply #6 on: July 02, 2013, 09:20:10 AM »
Yes, I hear the sound of a servo hunting around centre.
Not necessary to disconnect red on KK.
« Reply #7 on: July 02, 2013, 01:24:24 PM »
I think it is the Frsky receiver as others have heard a hunting sort of noise.
« Reply #8 on: July 03, 2013, 08:19:14 PM »
Omg - don't know if you can see in the pic but the pre soldered bullets on the motors must have been done with warm carrot instead of a soldering iron - another lesson learnt ! Guess which motor this is !!
« Last Edit: July 03, 2013, 08:26:46 PM by Ant »
« Reply #9 on: July 03, 2013, 08:46:40 PM »
rear right?
« Reply #10 on: July 03, 2013, 08:51:49 PM »
Oh yes ! Cheers for the help identifying the prob.
« Reply #11 on: July 03, 2013, 09:31:42 PM »
Was banking my H quad in a turn and it just dropped out of the air today, 4 broken props!
My KK2 christening, think I might go back to KK1.4...
« Reply #12 on: July 03, 2013, 09:50:57 PM »
;) no problem, easy enough to identify the offending arm just see what one drops first :) done it on Phil's disco a few times.
« Reply #13 on: July 04, 2013, 05:34:50 AM »
.....better off removing all bullets anyhow and soldering direct.
  • Dot Users: 8
  • user rdr
wanting a few bits by lkparky
[March 28, 2015, 10:05:14 PM]
Mobius lens A by lkparky
[March 28, 2015, 09:56:37 PM]
Page created in 0.323 seconds with 19 queries.
