  • Suggestions for new camera
[Today at 01:20:43 PM]
[June 02, 2015, 09:32:05 PM]
Flyingwings Venturi Evo build by Tecnic
[June 02, 2015, 10:50:33 AM]
Happy Flyers on tour Part 1 - Millau Viaduct FPV with nasty surprise by MatthiasC
[June 01, 2015, 12:06:01 PM]
[June 01, 2015, 11:56:48 AM]
[May 29, 2015, 10:38:24 PM]
[May 28, 2015, 04:31:42 PM]
Spanky 5 Action by gavnthat
[May 27, 2015, 09:39:49 PM]
FPV Racing Rear View Camera Action by MrBen
[May 26, 2015, 05:38:40 PM]
FPV in the sunshine :) by xxpitt
[May 24, 2015, 10:44:17 AM]
GemFan killers: DragonFly Bulletproof propellers for Mini Quads by Dan
[May 27, 2015, 01:11:00 PM]
[May 20, 2015, 05:48:31 AM]
Author Topic: Suggestions for new camera  (Read 1501 times)
« on: May 31, 2013, 10:25:58 AM »
Guys
Im after a new camera in the £50 region. Is the sea wolf still the dogs ??
http://www.securitycamera2000.com/products/690TVL-Ultra-WDR-Pixim-SEAWOLF-HD-CCTV-Mini-Camera-2.8mm-Lens-OSD.html
Cheers
Ant
« Last Edit: May 31, 2013, 10:31:55 AM by Ant »
Re: Suggestions for new camera
« Reply #1 on: May 31, 2013, 11:45:50 AM »
The Seawolf is probably the best daylight camera out there, comparatively it's a bit expensive, the uncased version is here:
http://www.securitycamera2000.com/products/690TVL-Ultra-WDR-Pixim-SEAWOLF-Sensor-Chip-OSD-Camera-2.8mm-Wide-View.html
Also consider the Sony Effio 650tvl WDR cams as they're good too and probably better at night and cheaper too
http://www.securitycamera2000.com/products/650TVL-SONY-Effio-DSP-CCD-Color-2.8mm-Lens-Camera-Multilingual-OSD.html
« Reply #2 on: May 31, 2013, 12:59:57 PM »
why the need to go as high as £50
my cased WDR600 only costs £30ish
the reason I get the cased version is for ease of mounting, the case on the pixim however is massive in comparison and very heavy.
Money no object, I'd buy the pixim every time, but if I had £50 spare and I needed a new FPV cam, I'd get the WDR600 and have £20 to spend on another LiPo or 2 from hobbyking :)
« Reply #3 on: May 31, 2013, 02:15:54 PM »
Cheers guys - what's the best way to mount a cam that hasn't got a case. I like the look of that 650
« Reply #4 on: May 31, 2013, 02:23:38 PM »
Not sure there is a best way, just mount however you can according to location and required angle
Thye have a hole at each corner if that helps
« Reply #5 on: May 31, 2013, 02:47:20 PM »
Does any one have the skills to cut me one of these from the dwg drawing???
They look like a cracking neat solution....
http://diydrones.com/profiles/blogs/fpv-camera-mount
Ant
« Reply #6 on: May 31, 2013, 02:51:03 PM »
here you go.... http://hobbyking.com/hobbyking/store/__12875__FPV_Fiberglass_Pan_Tilt_Camera_Mount_L_Size_.html
then you have pan/tilt if you want. I prefer just pan as I have no way to control the tilt (lost my head tracker cable for the predators)
« Reply #7 on: May 31, 2013, 02:52:23 PM »
oh, and marcin is offering to cut things : https://fpv-forum.com/index.php?topic=2417.msg15541#msg15541
« Reply #8 on: May 31, 2013, 04:36:34 PM »
You don't need that complexity, just use a bit of corruplast (sp ? )
« Reply #9 on: May 31, 2013, 04:48:03 PM »
But I like it :-(
« Reply #10 on: May 31, 2013, 10:49:25 PM »
securitycam2000 also sells hard cases, you can cut the board down and fit it in the case, that way you have a mount and the board is protected.
I'd still go for the sea wolf though (if you can afford it)
Offline chrisallen649
« Reply #11 on: May 31, 2013, 11:41:19 PM »
i have the effio-p 700 tvl 2.8mm board cam on my new quad. If you want to see stock settings of that cam look on his crash video of my quad
« Reply #12 on: June 01, 2013, 01:38:10 AM »
didnt manage to record much Chris Allen Fly Away Quad
« Reply #13 on: June 01, 2013, 01:43:04 AM »
if you want light, small and simple (no osd) this is the last one I bought from sc2000
Fastest FPV Funjet 278kph Small | Large
http://www.securitycamera2000.com/products/SONY-CCD-540TVL-Mini-30mm-X-30mm-X-10mm-FPV-Camera-with-Built%252din-MIC.html
Only 14g (plastic housing) and has a built in mic
« Reply #14 on: June 01, 2013, 12:20:35 PM »
I'm tempted Ben
  • Dot Guests: 27
  • user Dan
Page created in 1.624 seconds with 21 queries.
