  • Push rods !
Flyingwings Venturi Evo build by Quagmire
[Today at 12:09:21 AM]
Drinkwater Park Raceway (test day) by xxpitt
[June 07, 2015, 10:51:38 PM]
AEROLITE 103 by bigMouse
[June 07, 2015, 08:39:05 PM]
Upgrading Predator V2 by bigMouse
[June 07, 2015, 09:08:19 AM]
[June 06, 2015, 05:57:19 PM]
Best FPV combinaison for reduced latency by bigMouse
[June 05, 2015, 06:11:25 PM]
Mini Skyhunter, a nice FPV airplanes by tellypan
[June 05, 2015, 09:18:44 AM]
[June 02, 2015, 09:32:05 PM]
Happy Flyers on tour Part 1 - Millau Viaduct FPV with nasty surprise by MatthiasC
[June 01, 2015, 12:06:01 PM]
[June 01, 2015, 11:56:48 AM]
FPVMODEL RaceGates by fpvmodel
[Today at 03:41:05 AM]
MFD Autopilot control by myrcfpv
[June 07, 2015, 06:41:55 AM]
RLink 433MHZ UHF LRS 16 Channel Transmitter 8R-S receiver by myrcfpv
[June 07, 2015, 06:22:43 AM]
GemFan killers: DragonFly Bulletproof propellers for Mini Quads by Dan
[June 06, 2015, 05:59:29 PM]
Author Topic: Push rods !  (Read 768 times)
Push rods !
« on: February 03, 2013, 01:36:28 PM »
I am building a new fpv wing and the kit has come with some hd pushrods. What's the best way to fix the threaded ends? They slide on to the pushrods but I'm not sure if I should epoxy or solder ?? Any ideas ?
Re: Push rods !
« Reply #1 on: February 03, 2013, 01:57:01 PM »
solder! they are a royal pain in the ass too, I spend 10x more time trying to get the solder looking nice than I do actually soldering them together
Push rods !
« Reply #2 on: February 03, 2013, 03:11:43 PM »
Ok so do you 'wick' the solder in or fill the end with solder and push the rod in ?
Re: Push rods !
« Reply #3 on: February 03, 2013, 06:24:52 PM »
If they are zinc coated then you'll need to take the ends down to bare metal with some emery paper, next tin the ends of the rod with solder.  If you don't tin the ends then your not going to have much success.
Pop the screwed ends into a blind hole drilled in a block of wood, heat the screwed end with the iron against the side of it and feed some solder into the hole (about 1/4 1/2 full).
Dip the rod end in some flux and place it in the hole, to the bottom, hold the iron there to make sure the solder is fully molten, don't move the rod while the solder solidifies.
Alternate method I've always used is to throw away those rods, get some 2mm or 3mm mild steel rod, whichever size you want to use. Welding rod will do, and thread the ends with a die...
Push rods !
« Reply #4 on: February 03, 2013, 07:24:05 PM »
Nice explanation Bigmouse - I will give it a go. Ta
Push rods !
« Reply #5 on: February 07, 2013, 08:38:11 PM »
Like a dream !! Cheers guys !
  • Push rods !
  • Dot Guests: 25
  • user ady.g.
Lightbridge, Phantom, GoPro, Black Pearl by xxpitt
[June 06, 2015, 08:57:21 AM]
Page created in 1.524 seconds with 21 queries.
