  • EzOSD Problems
[Today at 09:18:35 AM]
[Today at 06:49:15 AM]
[Today at 06:25:48 AM]
FPV Related 3D Prints by mark1975
[Today at 06:25:12 AM]
BFPVRL @ ROTORS FLY IN by the famous xxpitt by MrBen
[Today at 06:01:17 AM]
Spanky6 Bank Holiday Monday Flights by MrBen
[May 10, 2015, 10:19:47 PM]
NEW FLIGHT CONTROLLER heads up by bigMouse
[May 06, 2015, 01:48:41 PM]
Author Topic: EzOSD Problems  (Read 2836 times)
EzOSD Problems
« on: January 15, 2012, 06:28:23 PM »
I seem to have missing info from the OSD, the bottom line of voltage and consuption ect dissapeared.
I was trying to hook up the RSSI and the bottom lines vanished. Now i cant get them to reappear or get any RSSI info displayed. Everything else works fine.
Ive checked all wires with a meter for bac connections and made sure the pins were in the right place from the diagrams every where.
I have no idea why.  :-[
Re: EzOSD Problems
« Reply #1 on: January 15, 2012, 06:50:03 PM »
ok I have had that too, I had to send the OSD back to sander for repair, it came back last week but to be honest I havent tested it yet, things to try first though are disconnecting ezuhf ... so you just got the current sensor and the osd, does it come back? also check you are in different video mode as one of them can stretch the screen and you may loose some info of the bottom (long shot that one) have you got a spare current sensor to try?
Eventually I ended up with 3 current sensors, 2 OSDs and 2 UHF rx, it helps when you come to troubleshoot to have more than one of everything LOL
Re: EzOSD Problems
« Reply #2 on: January 15, 2012, 07:13:09 PM »
Damn, i was hoping you wouldnt say that, thanks for the reply.
Hooking up the orig wire so its just current sensor straight to OSD doesnt bring the info back. I have no spare CS to try.
By video mode do you mean margins? I just flicked thru them and it just moved the top line around, the bottom line didnt appear.
Re: EzOSD Problems
« Reply #3 on: January 16, 2012, 11:41:53 AM »
Ive ordered another current sensor to try out. Hopefully that will solve my issues.
Re: EzOSD Problems
« Reply #4 on: January 16, 2012, 01:12:28 PM »
Ok let us know how u get on, I was trying to find a copy of the letter I sent to sander last night which outlined the problems I was having couldn't find it but I'll have a another look later as I'm sure one of them was the same as yours. Also where r u? If you ain't far away your welcome to pop over to try your gear.
Re: EzOSD Problems
« Reply #5 on: January 16, 2012, 01:25:36 PM »
Thnax for the offer, think im quite far away tho. Im just outside London.
If you find the letter pls post a copy and if possible the reply from Sander. Thanks for the help.
ssassen
Re: EzOSD Problems
« Reply #6 on: January 16, 2012, 04:15:12 PM »
@Ratty,
You checked this? http://www.immersionrc.com/documents/current_sensor_issue_28_11_2011.pdf
Re: EzOSD Problems
« Reply #7 on: January 16, 2012, 04:17:51 PM »
Hi Sander, yer i saw that thanks. I checked as soon as i received it and couldnt feel or see any pins trying to stick thru.
Re: EzOSD Problems
« Reply #8 on: January 17, 2012, 06:29:53 AM »
I checked my emails, I had one OSD that wouldnt display the current/rssi infor at all. I also had a UHF rx that when I plugged in a perfectly good OSD into it also the current/rssi info went off screen. If you have no luck with your new current sensor and you dont know anyone local you're welcome to send me the stuff (Cheshire) to test for you, as I said before it makes a hell of a difference troubleshooting when you have a 100% working setup already, just swap components one by one.
> Faulty EzOSD : Wont display current info or RSSI info, both the bottom 2
> lines of the OSD are missing completely (been trouble shooting and
> testing to resolve this for months)
> Faulty EzUHF Rx : Ok this rx was bought in March 2011 (I got all my
> immersion uhf stuff from Tim) I have noticed sometimes I loose link with
> this rx, recently when I power up the plane sometimes it doesn't come on
> at all, this is a temperamental fault. Also I discovered in the last
> week that if I hook up the OSD link cable from this rx to my fully
> working brand new EzOSD then I again loose RSSI and Current info,
> however when I unplug the OSD Link cable the current info comes back at
> the bottom of the screen, When I do a straight swap for my older EzUHF
> everything works as it should, current and rssi info there. I know this
> looks like a simular problem to the faulty OSD problem but I do believe
> it to be a seperate issue.
Re: EzOSD Problems
« Reply #9 on: January 17, 2012, 10:48:30 AM »
Thanks Ben, that sounds just like what happened to me. My new CS will be here today i hope, so ill test it and let you know.
Thanks again.
Re: EzOSD Problems
« Reply #10 on: January 17, 2012, 11:28:04 AM »
Well my new CS arrived, but it didnt solve my problem. Still no bottom line of info.  :(
Re: EzOSD Problems
« Reply #11 on: January 17, 2012, 12:50:44 PM »
Well it's either the connecting cables or the osd, I can check the OSD for you or you could contact either the vendor or Sander, I'd try the vendor first assuming you got it in the uk.
Re: EzOSD Problems
« Reply #12 on: January 17, 2012, 01:30:39 PM »
Sadly, i got the OSD from HK, and their customer support isnt the greatest.
I dont think it can be the cables (as far as i know) i have checked them with a meter and there are no bad connections or shorts as far as i can tell.
I sent you a PM about shipping it to you to test.
Re: EzOSD Problems
« Reply #13 on: January 20, 2012, 06:13:04 PM »
this is how my uhf is hooked up, plugs are drawn in the same orientation as the photo's you sent me
Re: EzOSD Problems
« Reply #14 on: January 20, 2012, 06:23:34 PM »
Ok thanks Ben. Ill give it a try soon and let you know the results.
  • EzOSD Problems
Page created in 0.572 seconds with 21 queries.
