  • Another UAV quad
Springbound Vid by Martink1974
[March 15, 2015, 09:31:19 PM]
marks emax 250 pro by mark1975
[March 15, 2015, 08:04:06 PM]
[March 15, 2015, 01:41:43 PM]
This looks interesting - Ritewing Drak by Martink1974
[March 13, 2015, 11:22:05 PM]
Another UAV quad by bigMouse
[March 13, 2015, 09:10:44 PM]
Storm 32 Brushless Gimbal Controller by MrBen
[March 13, 2015, 06:40:56 PM]
FPV Spanky Magic Smoke Edition by JAB1a
[March 13, 2015, 11:06:18 AM]
Had enough of Naza, going APM by Tecnic
[March 12, 2015, 10:00:10 AM]
FPV Related 3D Prints by Mancini
[March 11, 2015, 04:26:12 PM]
Introducing the "Wipeout - by Happy Flyers" by MatthiasC
[March 09, 2015, 12:41:58 PM]
More mini fun and more crashing by bigMouse
[March 09, 2015, 08:39:30 AM]
Spanky6 2k Res by MrBen
[March 08, 2015, 08:08:22 PM]
anyone flying the weekend? by mark1975
[March 08, 2015, 12:57:37 PM]
Cobs mini Tricopter on 2s with 5x3 props by MrBen
[March 08, 2015, 12:28:37 PM]
naughty quad by xxpitt
[March 07, 2015, 04:22:55 PM]
FMX250 LED Mini Quadcopter ARF RTF by Tecnic
Ultra Wide 1.8mm FPV CCTV Camera Lens 12mm MTV Thread by Tecnic
LHCP Skew Planar/Clover Sets by Tecnic
New 5.8Ghz Diversity Receiver by Tecnic
New Mini 600mw 5.8Ghz TX 12.8 grams and push button by Tecnic
[March 11, 2015, 11:30:44 AM]
Pages: 1 2 [3]
Author Topic: Another UAV quad  (Read 1098 times)
Re: Another UAV quad
« Reply #30 on: December 28, 2014, 12:44:53 PM »
Wanted to tart up the ends of the arms!
These end caps are drawn up and printed laying on their side, gets a better finish. Intended to fit into 15mm sq tubing from Wickes (13mm sq inside).
Layer height 0.15mm Tried 0.1 but the finish wasn't much better!
Print speed 50mm/s
PLA
support on.
210/60
« Reply #31 on: December 28, 2014, 12:46:13 PM »
Here they are fitted to the UAV. Seems to finish it off nice!
« Reply #32 on: December 28, 2014, 12:49:48 PM »
Just out of interest, here is a smaller version to fit 100 sq tube!
« Reply #33 on: January 29, 2015, 07:13:29 PM »
Had chance to look at the telem antenna, wanted some kind of cable grip to hold the cable feeding the antenna, wanted this to take any strain instead of the soldered ends! This is what I came up with!
Made from rigid PLA it is springy due to its shape, the cable is held centrally, the grip is pushed into the square tube, a little round protrusion fits holes in the tubing so that it can lock anywhere there is a hole.
« Reply #34 on: March 13, 2015, 09:02:58 PM »
About 2 years ago I bought a load of CF prop blades from China, at the time I didn't realise they were the T motor (2 bolt type) and never had any motors capable of mounting them on, so still have them all!
FPVModel (advertised on this forum) sell motors with this style of mounting so thought it a good idea to upgrade the UAV
The original system: The NTM 1000kv PropDrive motors were fine, the prop adapters seemed to run quite true, the cheapo props were called 'cf reinforced', but was unable see any cf on the ones I broke!, They never broke in flight, but quite fragile if in contact with anything! they were 10X4.5
« Last Edit: March 13, 2015, 09:05:16 PM by bigMouse »
« Reply #35 on: March 13, 2015, 09:10:44 PM »
The upgraded system uses fpvModel motors, same 1000kv, full CF props 10X5.5. Main advantage is the lighter, airfoil shaped props, slightly more pitch! Hope they are better ballanced than the old props! (and stronger!) Haven't tested them out yet!
Mounting holes ( the longer direction was the same 19mm on both motors so it was an easy matter to swap them over! fpvModel motors come with bullet connectors in the box, so need to solder them on! Nice quality motor leads.
Pages: 1 2 [3]
  • Another UAV quad
  • Dot Guests: 32
  • user huioliver
Wanted : LaserBGC 1.3 module for fatshark goggs by MrBen
[March 07, 2015, 07:05:53 PM]
Best legal long range setup by BIRDS-EYE-VIEW.NL
[February 27, 2015, 03:57:22 PM]
Page created in 1.199 seconds with 20 queries.
