  • Mobius 1080p Action Camera
Best FPV combinaison for reduced latency by bigMouse
[Today at 06:11:25 PM]
Mini Skyhunter, a nice FPV airplanes by tellypan
[Today at 09:18:44 AM]
[June 04, 2015, 09:01:00 PM]
Flyingwings Venturi Evo build by MrBen
[June 04, 2015, 09:00:33 PM]
[June 04, 2015, 02:30:52 PM]
[June 02, 2015, 09:32:05 PM]
Happy Flyers on tour Part 1 - Millau Viaduct FPV with nasty surprise by MatthiasC
[June 01, 2015, 12:06:01 PM]
[June 01, 2015, 11:56:48 AM]
[May 28, 2015, 04:31:42 PM]
Spanky 5 Action by gavnthat
[May 27, 2015, 09:39:49 PM]
GemFan killers: DragonFly Bulletproof propellers for Mini Quads by fpvmodel
[Today at 11:09:59 AM]
Pages: 1 [2] 3 4 ... 6
Author Topic: Mobius 1080p Action Camera  (Read 11801 times)
Re: Mobius 1080p Action Camera
« Reply #15 on: August 15, 2013, 05:30:46 PM »
what's it going on Ant? if you're tight on space, then it should be fine to use as flight cam using the AV out but make sure you keep it powered using a spare channel on your RX
if you've got room for both, i'd definitely recommend using the 600TVL cam for flight cam, that way you can move the mobius around the aircraft to get different angles in HD :)
« Reply #16 on: August 15, 2013, 07:18:59 PM »
It's going on a quad copter - one of those discovery copies. Gone cheap as I want to have a play with a apm 2.5 !! Yep I know I might regret it but I fancy a go anyway as I like to fiddle :-) Will go for both cams I think .
« Reply #17 on: August 16, 2013, 10:20:42 AM »
yup, I think 2 cams is the best bet.
look forward to seeing your results with APM... it's a great bit of kit... I literally don't have the patience for it though :)
Offline motofox
« Reply #18 on: October 01, 2013, 12:35:20 AM »
Had some good video with the mobius. its been very good so ordered another one. the Av out is also very good so cannot complain for the money.
« Reply #19 on: October 01, 2013, 07:13:52 AM »
motofox you say you ordered another one, is the original one still working ok? I think Im going to buy one myself.
« Reply #20 on: October 02, 2013, 05:21:49 PM »
Uk reseller of mobuis here chaps
http://joovuu.com/index.php
Currently out of stock till around the 9th October though!
Offline Jake Bullit
  • "Roads? Where we're going, we don't need roads."
« Reply #21 on: October 16, 2013, 12:47:44 PM »
Any one using this as a flight camera?
Fly,crash,glue,repeat!
« Reply #22 on: October 16, 2013, 09:31:39 PM »
assume you seen this video jake
http://youtu.be/yMkN9Vv7GsE
« Reply #23 on: October 16, 2013, 09:43:33 PM »
think i prefer standard lense over wide angle
Mobius Wide Angle vs Standard Lens Small | Large
« Reply #24 on: October 16, 2013, 09:52:24 PM »
wide angle defo not as sharp
« Reply #25 on: October 16, 2013, 10:37:05 PM »
Was going to order wide might stick with stand ill wait unti tomoz as it gives the 17th as expected in stock.
« Reply #26 on: October 16, 2013, 11:01:41 PM »
Quote from: Mark1975 on October 16, 2013, 10:37:05 PM
I reckon Ady should be the guinea pig on these,he sure needs one..lol
« Reply #27 on: October 16, 2013, 11:07:20 PM »
Quote from: brodjackella on October 16, 2013, 11:01:41 PM
+1
« Reply #28 on: October 17, 2013, 06:35:29 AM »
Update standard  due in 18th......wide angle instock 15 units they will soon go.
« Reply #29 on: October 17, 2013, 05:08:05 PM »
GOPRO 3 Vs MOBIUS ACTION CAM ON WALKERA QR X350 QUADCOPTER Small | Large
  • Dot Guests: 32
  • user Fpvalb
  • user Hagar666
Lightbridge, Phantom, GoPro, Black Pearl by loganj13
[June 04, 2015, 09:34:15 PM]
Page created in 1.621 seconds with 22 queries.
