  • correct di-pole mounting?
Introducing the British FPV Racing League by gavnthat
[Today at 07:49:35 PM]
Pages: 1 [2]
Author Topic: correct di-pole mounting?  (Read 1741 times)
Re: correct di-pole mounting?
« Reply #15 on: May 28, 2013, 05:07:45 PM »
Quote from: CorporalB on May 28, 2013, 11:39:14 AM
however.... just out of interest... how can I tell which one is signal or ground? it came with the rangelink set so I didn't make it... the "spilt" is heat shrinked over so I don't know which one comes from the centre of the cable.
can you check with a multimeter?
« Reply #16 on: May 28, 2013, 05:42:18 PM »
asked the multimeter... he didn't know either ;)
« Reply #17 on: May 29, 2013, 08:40:20 AM »
If you really want to know, use the MM in ohms (or continuity) mode. One probe on the antenna sma nut and the touch the end of the antenna wire with the other probe. If the wire is retracted into the insulation, use a pin to pierce through the insulation! good for finding exactly where an open circuit is  too. Not advisable for high voltage circuits though!
« Reply #18 on: May 29, 2013, 11:25:36 AM »
what would the MM show if I "probed" the signal wire?
« Reply #19 on: May 29, 2013, 11:35:41 AM »
If one mm probe is touching the sma nut and the other probe touching the signal wire then it would be open circuit reading (infinity), then touching the other element would show short circuit (zero Ohms)
Totally different point but if you want to check continuity of the signal element (particularly after a crash) then unscrew the sma connector and test between the center pin and dipole element for zero Ohms.
Pages: 1 [2]
Page created in 0.552 seconds with 22 queries.
