So you won't be able to upgrade the firmware on that chip without using an ICSP programmer, which can destroy the board if used incorrectly (wrong fuses set).
for some reason they messed up the 32u2 firmware, and it doesn't come with the DFU bootloader (it just has some unknown version of ArduPPM flashed directly).
Hi Saurabh, Your confusion is understandable and I suspect it's a little what Chris intended. He wants to scare you out of buying an RCflyer and push you into buying from his company, 3DR. A normal reaction, he's protecting his income. Let me assure you that you CAN upgrade to arducopter 2.9 on the arduflyer when it comes out, just like with a 3DR board. The 32u2 chip is the small processor that handles your inputs from your receiver, combines them and feeds them to the main atmega2560 processor. Actually this chips hardly ever needs updating. I've never update mine in 3 years. Updating a new arduplane/copter firmware is done on the atmega2560 chip (not the 32u2), which works just fine on the arduflyer, either with arduino or with mission planner. The fact that the arduflyer comes with the latest stable arducopter firmware loaded is just an extra service from RCTimer. You can change this firmware on the arduflyer, just like with 3DR boards. I have changed the firmware on my arduflyer to arduplane 2.66 with mission planner. So in short, as a normal enduser you most likely will never have to update that 32u2 chip. You shouldn't worry about it.
How you getting on with this Chris ? Any autonomus flights or fpv flights ? Are you using the Minim OSD or the Remzibi ?
here you go Jethro: http://www.unmannedtechshop.co.uk/uav-components/ardupilot-mega-uk/ardupilot-mega-2-5-case-top-entry.html although postage is actually more expensive than the product.
Quote from: CorporalB on January 09, 2013, 12:09:36 AM here you go Jethro: http://www.unmannedtechshop.co.uk/uav-components/ardupilot-mega-uk/ardupilot-mega-2-5-case-top-entry.html although postage is actually more expensive than the product. byod has them in stock again the postage is more than the case! my auto pilot arrived today from rctimer so its in the queue for testing in the bixler after I have tested the UHF open LRS unit. Sent from my Nexus 7 using Tapatalk HD
